Old 20-09-12, 10:35 PM   #1
rivsm
Default dwg or dxf pls
Hi Guys n Gals
Im trying to get a fender eliminator done and came across this thread: http://homepage.ntlworld.com/junej.h...te/rse_end.htm
Ive emailed it to a company who specialise in metal fabrication, however they have in turn asked if I can supply them with a dwg or dxf file of the dimensions. I was wondering if anyone has this template in these formats please.
Thanks in advance
Old 20-09-12, 10:54 PM   #2
MisterTommyH
MisterTommyH's Avatar
Default Re: dwg or dxf pls
I might be able to scan that in and use a .pdf to .dwg converter. Wouldn't be perfect, because it might facet some of the curves (slightly - not so you'd notice with your eyes).
Problem is I'm going to be stacked out until the end of the month. If you're still not sorted by the 1st send me a PM and I'll see what I can do.
MisterTommyH is offline   Reply With Quote
Old 21-09-12, 09:18 PM   #3
rivsm
Wow, Thanks for that MisterTommyH. Im bogged down with a new job at the moment so if I cant sort anything out, I will defo take you up on the offer.
