Old 21-09-12, 06:30 PM   #1
xlv
Default GSXR RWU forks and stock SV wheel?
made the stock wheel and speedodrive fit with spacers and such, iīm talking curvy here. searched but couldnīt find something about it. may get my handīs on a gsxr600 RWU for a good price.
//M
Old 21-09-12, 06:46 PM   #2
Default Re: who has changed the fork and...
Yes, mines got a GSXR 750 front end with OEM front wheel & speedo
Requires a one off spindle & spacers.
My front end is from a L or M model, so the steering head bearings are the same as the SV
Old 21-09-12, 06:48 PM   #3
simple answer, you don't but i think i remember seeing somewhere you can with a bit of jiggery pokery run it off the back.
better to get a complete front end with wheel etc.etc and the bearing from TWF. for your speedo just use a hall effect with 4 evenly spaced magnets and if you have the OEM discs then its a piece of cake.
Old 21-09-12, 06:51 PM   #4
//M
If you can get a GSXR600 front end, do bother with faffing about trying to make the SV wheel fit it. Its far simpler to use a Hall Effect sensor and magnets for the speedo
Pretty sure Yorkie Chris has GSXR 600 RWU front end on his
Old 21-09-12, 06:54 PM   #5
the cheapest solution to getting cartrage internals is to get a hold of CBR600 f3 forks and transplant the stanchions and dampers onto the SV lowers.
Old 21-09-12, 07:44 PM   #6
This. Also opens up the choices of fronts, there was a track curvy with a original R6 front not so long ago
Biblo you did build a hall effect bracket a wee while ago?
YC has a SRAD front to my knowledge (or whats left of it)
Good shout and reminds me to get my arris into gear and start sorting things out for a transplant of evil goodies
Old 22-09-12, 07:01 AM   #7
xlv
Ok, but by doing this you still have the sv lowers that miss the screw in the bottom that makes an forkoil change som much easier.
Old 22-09-12, 07:04 AM   #8
xlv
Ok, guess the L and M stands for years of produktion, the fork i looked at is SRAD and the bearingpart is allready sorted. Do you have pics of your mod ?
Thankīs Mike
Old 22-09-12, 07:24 AM   #9
SRAD is probably the most often used I think, do a search on here for it, thee's loads of info.
Here's mine. The guy I bought the front end off had the spindle made for me, bu its not a difficult one to make by the look of it.
Old 22-09-12, 07:51 AM   #10
xlv
thankīs nice work, and i see you have the USD fork on too, guess iīll be spending some time on ebay to day
What is stock fork oil for GSXR 750 SRAD forks? TamSV Bikes - Talk & Issues 21 08-01-11 12:37 PM
Srad wheel on gsxr 1000 k2 forks? widget Bikes - Talk & Issues 3 19-10-10 11:35 AM
GSXR 750 k4 wheel with GSXR 600 K7 forks Bunks Bikes - Talk & Issues 12 05-05-09 06:36 PM
K4 gsxr forks - which wheel? buttmunch SV Talk, Tuning & Tweaking 25 31-05-06 11:28 AM
Swap GSXR forks/radial brakes/radial master cylinder/wheel Teknic SV Talk, Tuning & Tweaking 2 16-03-05 07:19 AM
