Old 08-10-12, 01:14 PM   #1
Default Spraying waxoyl?
Hey folks,
Going to add a bit of rustproofing to the underside of the mighty vito.
Have got some waxoyl-esque stuff from local oil supply place and am wondering how to apply it.
I've brushed similar things on before but it takes ages and is messy, the guy recommended thinning it a bit with turps and spraying it on with a garden bug-sprayer.
I know there are some people with landies on here that must be having (losing) a battle with rust so any experiences welcome
Old 08-10-12, 01:19 PM   #2
Luckypants
Luckypants's Avatar
Default Re: Spraying waxoyl?
Thin it by heating up the drum Chris. I had a mate that used to rust proof Japanese grey import cars with Waxoyl, he always heated the stuff so it would flow better. He then sprayed using a normal air powered spray gun thing.
Old 08-10-12, 01:31 PM   #3
What about rolling it on Chris? You'll be able to get it on thicker and won't have to thin it.
Old 08-10-12, 01:35 PM   #4
Too many nooks and crannies
Old 08-10-12, 02:28 PM   #5
embee
embee's Avatar
If you use a garden type sprayer (which work OK) bear in mind the solvents in the waxoyl stuff. Garden sprayers usually come in 2 flavours, water based and solvent based, presumably O-ring materials different. I have used a "watery" one with some floor sealant before, and it wasn't very happy a couple of days later though it did seem to recover after a few months.
Heating I agree, some of them seem to be prone to forming wax crystals in the can which can clog things up, a decent strainer on the pick-up recommended.
Old 08-10-12, 02:33 PM   #6
Fence sprayer better than a plant sprayer then?
Old 08-10-12, 02:59 PM   #7
cdtrim
I used to work for a company that sold waxoyl, IIRC they sold a dedicated sprayer made by the same people. I think it was a hand cranked system similar to a weed sprayer. Not sure if it would be too thick though to go through the nozzle on a normal type garden or paint sprayer.
Old 08-10-12, 04:07 PM   #8
Biker Biggles
Biker Biggles's Avatar
Thats right.I had one and it worked OK but much better if the oil was hot.
Old 08-10-12, 05:03 PM   #9
AndyBrad
Warm it up and keep the tin sat in as warm as possible water bath as your using it.
Secondly it gets everywhere (apart from where you need it) so cover everything or do it on someone else's driveway as its a pain afterwards
Sent from my GT-I9300 using Tapatalk 2
Old 08-10-12, 05:20 PM   #10
You've got a compressor, get one of the specific sprayers and it goes on dead easy. Loads on ebay, I think I paid about six pounds for mine.
Spraying... ThEGr33k Bikes - Talk & Issues 9 01-09-11 05:12 PM
Spraying danf1234 SV Talk, Tuning & Tweaking 2 16-10-10 06:16 PM
Spraying plastics. Tomtoms Bikes - Talk & Issues 3 19-02-09 02:27 PM
Re-spraying diamond South & West Surfers 13 10-09-05 07:20 AM
Home spraying northwind SV Talk, Tuning & Tweaking 18 04-04-05 04:06 PM
