Afternoon all, have noticed recently that the bike is not revving past 8/9k, regardless of speed or gear. Bike is absolutely great below those revs-runs and pulls as it should do.
Tried searching a few thread on here and on google. Some of the items i should be looking at are; Air Filter spark Plugs TPS Fuel delivery Compression Valve tolerances Best to start with the basic stuff 1st. What is the best way to check fuel delivery; pipes routed well, not cracked/leaking injectors getting fuel through fuel filter not blocked Any other input/tips of what i should be looking for? TIA |
Ecu limiting it due to a fault?. Would the test plug process show anything?
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
is the bike jerking at 8/9k or just a smooth drop off?
how well does it start? will it rev past 8/9k in neutral? is there a slight hissing or parping sound? you can rule out the air filter unless its completely blocked with a birds nest. |
Some guy on here had the same problem at 6k revs , think it was something to do with his battery, check that
Sent from my iPad using Tapatalk |
#5 | |||
Drops off and then starts to become jerky. Starts on the button every time, never had any starting issues with it. Can't hear any un-normal sound, the power simply disappears it's k & n, so cleaned and refreshed it anyway. Quote:
Update; Have checked air filter, cleaned and refreshed. Was clean anyway. Checked fuel lines-all good, no kinks, cracks or leaks. Got the spark plugs out. They have a bit of soot on them are are still at 0.75mm gap. |
i was going to say.
have you checked that the battery terminals are tight? spark plugs seated properly? vacuum bungs in place and not cracked? |
Yeah battery terminals are good and tight.
Spark plugs were seated properly. Where are the vacuum bungs loacted? |
at the bottom of the TB's http://forums.sv650.org/showpost.php...&postcount=105
#9 |
Got new spark plugs and installed them. Bike revs absolutely fine to 11k.
Going to go out for a ride on it tomorrow and see if it still lacks power. Hoping that something i have done today has cured it, if not at least i've narrowed down the list of things to check! |
#10 | |
Crash.NET - Pedrosa: The past is the past | NewsBot | News | 0 | 27-09-12 10:20 PM |
Not revving past 11,500rpm in 6th | hongman | SV Talk, Tuning & Tweaking | 69 | 12-08-11 09:19 PM |
Bike revving out? | ibshort | SV Talk, Tuning & Tweaking | 6 | 27-08-09 11:12 AM |
curvy revving | mikey09 | SV Talk, Tuning & Tweaking | 3 | 04-04-09 04:32 PM |
Is there any way of revving higher ? | boo86 | SV Talk, Tuning & Tweaking | 13 | 28-02-09 04:55 PM |
