Old 18-10-12, 11:47 AM   #1
M65
Default ZZR1400 Shock Specs?
Im in the market for a ZZR1400 shock, as talked about here However, I have seen the google docs spreadsheet which list specs for a 2006-2008 ZZR1400 shock, but I could do with the specs for a 2010 model ZZR1400 shock. Does anyone have a link to such info?
Old 18-10-12, 02:00 PM   #2
Default Re: ZZR1400 Shock Specs
according to RA 2006-2010 is same shock
Old 18-10-12, 02:26 PM   #3
Default Re: ZZR1400 Shock Specs?
also looking at the spring rate calculator. a 9.7 spring is suitable for 18st rider without gear. 15st rider without gear is 8.5. both figures are calculated for a bike with a semi wet weight of 390lb.
so if your 17-19st nekit then the standard spring on the ZZR14 will be perfect. if your under 17st then you will need to get it re sprung.
i can also tell you that the pointy does not like having a stiff spring. been there, done that and its not a nice experience.
Old 18-10-12, 04:30 PM   #4
Runako
I can also tell you that the pointy does not like having a stiff spring. been there, done that and its not a nice experience.
ZX10r shock better rate for that weight?
Old 18-10-12, 05:51 PM   #5
what year?
Old 18-10-12, 07:25 PM   #6
Runako
what year?
I think it was the 07/08 that I got.
Old 18-10-12, 07:39 PM   #7
there is a big difference between the 07 and the 08.
i would say the 07 is good for a 14-15st rider while the 08 is good for a 16-17st rider
Old 18-10-12, 08:01 PM   #8
Runako
One day I'll stop talking out my ass! Not only do I have the spreadsheet and the shock info (on my PC) but could I be bothered to look? No.
I have a ZX6R shock 07/08 which is 515 according to the sheet and 10mm over stock. It feels suitable to me (between 14/15 with gear). Tbh I know its alright but wouldn't mind the feedback anyway Bibio.
Old 18-10-12, 08:35 PM   #9
Fozzy
Docs
https://docs.google.com/spreadsheet/...sOXo4Qnc#gid=1
https://docs.google.com/spreadsheet/...COvG24gH#gid=1
those show the same spring weight for 06 to 08!? *confused*
Old 18-10-12, 09:04 PM   #10
confusion is zx10 not zx6.
zx14 still stands to what i said.
zx6 07-08 will be same as zx10 08 or there abouts for rider weight but the big difference is the 10mm which will be 20mm at back end. this will set the rate to a much softer area never mind the geometry changes. personally i would put longer dogbones on the bike to accommodate the difference in length as that is waaaay to much. it's a misconception that making the rear of the bike higher is better just like stiff suspension is better which in fact is bull.
what i would suggest you do is go on google and start reading up on bike geometry (pay attention to swingarm position) then come to your own conclusion as i have said all along i am no expert. i give advice and it's upto the individual whether they want to take it or not.
ZZR1400 Shock Fitting? M65 SV Talk, Tuning & Tweaking 29 17-03-13 07:18 PM
SV1000 Shock in my 650, are these stiffer or the same sort off specs? cmjhs SV Talk, Tuning & Tweaking 0 01-05-12 12:35 AM
Zzr1400 08 abs dizzyblonde For Sale - Other Bikes and General biking items 8 20-03-12 02:49 PM
Which bolt do I need for ZZR1400 shock on a pointy? SAMMY650 SV Talk, Tuning & Tweaking 4 17-09-11 04:39 PM
Tech Specs on a Pointy Rear Shock SoulKiss Bikes - Talk & Issues 2 28-02-07 08:43 AM
