Old 19-10-12, 11:25 PM   #1
chezvegas85
Default Sticky back door
Oi oi, not as exciting as it sounds
The back door on the house is becoming a pain in the bottom (back door, bottom) to close now its gettin cold (wooden door + window, Wooden frame).
Should i just lube it up? (back door, pain in the bottom, innuendo police?) appropriate lube suggestions here... (i have cooking oil, butter and wd40)
or is there something else more appropriate i should do, its a rented house so not a major problem, just dont really want to knee the door shut at 1am when i've been out to the garage to cuddle my sv n av a sneaky fag for the rest of the winter
Old 19-10-12, 11:28 PM   #2
tigersaw
tigersaw's Avatar
Default Re: Sticky back door
candle wax lubes wood well
Old 19-10-12, 11:30 PM   #3
chezvegas85
wow, that still sounds post watershed. cheers pal
Old 19-10-12, 11:35 PM   #4
So the door has swelled?
Reasons why doors swell in wet damp weather is, its an natural product so will always 'move' but the most common mistake people make is not painting or staining the whole door, sides, top and bottom need to be done, this reduces the amount of moisture the door will absorb.
Back to the current problem, it will need planing, do it while it's like this and next time it swells, it should still close ok.
Old 19-10-12, 11:36 PM   #5
Fallout
Fallout's Avatar
My back door swells when it gets wet (wayhey). Garage door that is. I attacked it with an angle grinder last winter and shaved the edge off. Then did it again and shaved some off the bottom edge. Still sticks. I've just decided I'll be kicking the crap out of it for the rest of it's days and it bloody deserves it too, the cheeky wooden swine!
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 19-10-12, 11:41 PM   #6
chezvegas85
unsure if the door has swelled or the has frame contracted. yes, i am an egit.
have a (compression, no flue) tumble dryer that steams everything up (although does save on central heating) so your probably right as the landlady seems to of botched just about everything, i have varnish from doing some cabinets, would that be suitable? dont want to be planing the door as i'm (as previously mentioned) an egit and its not my house. May invoke cx5's friendship clause as he's good with wood...oh dear
Old 19-10-12, 11:42 PM   #7
chezvegas85
haha tbh fallout, that seems a bit of a tame response for yourself. not a single mention of the disposal of corpses for instance
Old 20-10-12, 08:00 AM   #8
keith_d
keith_d's Avatar
It could be your dryer, but it's usually the wind. It blows rain onto the face, which goes down and into the crack at the bottom. In this weather it never dries out so your wood swells and it sticks at the bottom. You will need the right tool for the job, an electric one would be best. But if cx5 knows how to deal with wood I'm sure he'll have one. (fnarr fnarr)
Or without the double entendres....
It's probably rain blowing onto the outside of the door, then running into the gap at the bottom. There it soaks into the wood making it swell up and stick. Use a power planer to remove a couple of mm from the bottom of the door, then two coats of gloss paint to stop it soaking up water in future.
Old 20-10-12, 08:57 AM   #9
Fallout
Fallout's Avatar
What are you implying?! *slaughters a goat to appease the evil Gods, ravages 20 maidens, ethnically cleanses jupiter*
Old 20-10-12, 09:43 AM   #10
Wideboy
Evel Knievel
Wideboy's Avatar
you wont need an electric planner, it will literally be two shavings right across the bottom then seal it. you have to remember as SP said timber expands and contracts, if you go whacking the bottom off with an electric planner the door will contract when the weather warms up and you'll be left with massive gap on the bottom of the door, resulting in drafts ect.
take the door of, shave it off with a HAND plane, check it fits, seal it (with an exterior paint, will be cheaper than varnish and colour doesn't matter as it won't be seen), the re-hang the door job done.
or as you say you have a landlady, then nag her to sort it, its someone cutting costs that's caused the problem in the first place. wouldn't possibly be the landlord tho
the only other thing it could be is the hinges or frame buckling under the weight but this is ruled out as the top, side corner would also be rubbing.
05 DRZ400E
RIP hovis
how to make sticky back vinyl work on curves? leebex Idle Banter 5 05-10-11 07:43 PM
Davy Knowles, from the Back Door Slam CD Bri w Idle Banter 1 10-02-10 11:16 AM
Sticky Back Brake branny SV Talk, Tuning & Tweaking 36 03-11-08 06:30 PM
sticky back brake on yer bike Bikes - Talk & Issues 4 16-11-06 05:53 PM
Scolded for going out my own back door! K Idle Banter 21 14-07-06 07:01 AM
