Old 30-10-12, 03:29 PM   #1
mackemforever
Default Which replacement chain & sprockets?
Ok, so after putting it off for a long time I finally need to replace my chain & sprockets, they are so worn that under any kind of acceleration I can feel & hear my chain skipping teeth!
So, can somebody recommend me the best value kit to replace both sprockets & my chain, being a student I'm not looking to spend much if possible although obviously I don't want anything that's gonna wear out quickly.
So, what would you guys recommend.
Old 30-10-12, 04:54 PM   #2
Viney
Default Re: Which replacement cable & sprockets
In all honesty, any kit. Just keep it lubricated and adjusted correctly and it will see over 10K Some have been known to get over 50k!!!. If you really want to make the chain last even longer, get a Suzuki OEM front sprocket. I was advised this by someone who i trust and my chain laster a lot longer then with pattern front sprocket that comes with the kits.
Old 31-10-12, 04:40 PM   #3
Default Re: Which replacement chain & sprockets?
Tsubaki alpha or sigma. Sigma is overkill and I wouldn't fit one unless you have a scottoiler.
I wouldn't bother with X rings as they're a gimmick at best.
I like JT sprockets.
Chain and Sprockets adoh30 Bikes - Talk & Issues 3 17-08-08 02:37 PM
Replacement chani and sprockets seedy100 SV Talk, Tuning & Tweaking 0 05-09-06 07:11 PM
Replacement Chain and Sprockets sharriso74 Idle Banter 7 22-05-06 11:51 AM
chain and sprockets adey Stuff Wanted 4 27-11-05 01:26 PM
Best Chain/Sprockets for SV '02? Joe rocket SV Talk, Tuning & Tweaking 4 01-03-05 08:49 PM
