Old 15-11-12, 05:15 PM   #1
Chris*2700
Default 2009 sv650s won't start.
I rode my SV all day Sunday, parked it up. Went to ride it to work on Tuesday, turn the ignition and nothing happens. The fuel pump doesn't prime, the indicators, parking/side lights work and so does the rear light but there is no speedo/display or anything and the headlights don't turn on and worst of all the bike doesn't start. Checked the battery and all fuses and all seems fine I don't know what else to do apart from take it to a mechanic. Any advice?
Old 15-11-12, 05:57 PM   #2
dr jekyll
Default Re: 2009 sv650s won't start HELP!!!
hi have you tried checking all the relays
theres on towards the rear of the loom which is linked to the fuel
cheers and good luck
Old 15-11-12, 06:01 PM   #3
turn your ignition on and wiggle the wires that come out the right hand side of the frame at the forks and see what happens.
Old 15-11-12, 09:43 PM   #4
Default Re: 2009 sv650s won't start.
Originally Posted by Chris*2700 View Post
Any advice?
Ummm... write a bit smaller maybe?
Old 15-11-12, 09:44 PM   #5
DJ123
DJ123's Avatar
How did you check the battery, and what figures did it give you?
BMW F800ST
Old 16-11-12, 06:47 AM   #6
Apart from making the text smaller as Sid said, you have done the obvious things like kill switch, side stand etc?
Old 16-11-12, 10:34 AM   #7
Chris*2700
Sorry about the text size it was an accident haha. I have tried the kill switch flicking it back and forth and the side stand button/switch. I haven't checked any of the relays and I will try wiggling the wires to the right of the bike today. I tested the battery by putting a multimeter on the positive and negative terminals. How would I go about testing the relays?
Old 16-11-12, 05:55 PM   #8
Runako
Do you have an aftermarket clutch lever?
Old 16-11-12, 06:48 PM   #9
kiggles
check the wires under the tank that comes from the ignition. mine did similar thing. did everything but start. problem was one wire had bad connection, just had to reconnect it.
For Sale - 2009 SV650S :( DaveRushton For Sale - SV's and SV related items 19 11-04-13 10:33 PM
FOR SALE - Suzuki SV650S, 2009/09 - £3,200 jfb For Sale - SV's and SV related items 0 13-07-12 10:51 AM
SV650S 2009 For Sale aaronmlyon For Sale - SV's and SV related items 0 24-10-11 07:24 PM
SV650s K8 2009 Reg for sale. RedMacgregor For Sale - SV's and SV related items 9 15-07-10 04:43 PM
2009 sv650s elkieboy For Sale - SV's and SV related items 6 15-06-10 07:14 PM
