Old 30-11-12, 08:38 PM   #1
Whitty
Default minimum mot requirements?
I think I'm gonna put an mot on my race bike for use by myself or to aid future selling. I am gonna put some small lamps on front and led rear with mini indies but my question is do I need the following-
Folding pegs
Mirror/mirrors
Side stand(I have it, don't want to cut race fairing to fit it)
Rear brake light switch(i heard only one has to work?)
Cheers whitty.
Old 30-11-12, 08:51 PM   #2
Default Re: minimum mot requirements?
Go to Grizzleys. The lads will help you with minimum requirements
Old 30-11-12, 08:59 PM   #3
joshwalker094
joshwalker094's Avatar
you dont need lights at all, if you run a daytime mot
RIP Reeder
JOSH WALKERRRRRRRRRRRR
Old 30-11-12, 09:02 PM   #4
side stand, yes or how are you supposed to park it up
if the switch is there it must be active e.g. lights including flash, side, lo and high beam. this also includes indicators. no lights then daytime only MOT.
number plate light and registration plate.
both front and rear brake light switches have to be working.
Old 30-11-12, 09:13 PM   #5
suzukigt380paul
although you can get a mot with out lights,there is no such thing as a daylight mot,and you may find it difficult to find a garage to give you a mot with out lights
Old 30-11-12, 09:29 PM   #6
I believe you need a rear brake light, horn and number plate and that's about it.
Don't think the sidestand is needed per se but it will be a pain in the *rse without one.
Old 30-11-12, 10:07 PM   #7
Whitty
All wiring and switchgear still in place so easy to fit some, plus I work shifts so if I go to work on it at least one way will be in dark. Reason I ask about both brakes working the lamp is I have rearsets on with no switch provision. I know I can get an inline one but do I NEED to? I could leave lowers off and fit stand I suppose but generally lean bar end on a wall in gear when not on paddock stands. What about mirrors and pegs?? Ps, like how you use 'per se' and 'pain in the *rse' in same sentence Chris.lol
Old 30-11-12, 10:17 PM   #8
leebex
number plate light came under construction and use regs, not MOT. Dunno if thats changed recently. wouldnt fail an mot, but plod might give you a tug.
Old 30-11-12, 10:21 PM   #9
Whitty
Will have one, I've found an 'E' marked rear led unit on eBay combining stop/tail/no.plate in one.
Old 02-12-12, 11:56 AM   #10
Ratty
Ratty's Avatar
You don't need rear pegs if no rear seat is fitted. Mine has passed MOT's at two stations with fixed front pegs ( Gilles ). Why do you think this may fail it ?
Ratty
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
does insurance get to a minimum limit? husky03 Bikes - Talk & Issues 11 05-12-10 11:21 AM
Minimum VDU Size for the Office? slloyd Idle Banter 10 08-03-10 08:56 PM
Tyres - Minimum tread depth Grinch Bikes - Talk & Issues 18 09-02-08 04:12 PM
Legal Minimum Gear Standard 454697819 Bikes - Talk & Issues 81 12-08-04 08:33 PM
