Old 04-12-12, 08:58 PM   #1
Wildkid
Default Alternative to jacking up a pointy for a shock swap?
I have paddock stands front and rear but each day pains me that I dont have a abba stand yet haha....
Im going to be doing a shock swap with the zx10 06-07 shock soon but was wondering how i could go about jacking the rear of the bike up to do this without a abba stand??
Need some orgers wisdom!
Cheers gents.
Old 04-12-12, 09:00 PM   #2
Nobbylad
Nobbylad's Avatar
Do a search for gixer swap with my username. Should be some photos
Old 04-12-12, 09:14 PM   #3
Wildkid
Default Re: Alternative to jacking up a pointy for a shock swap??
Do you mind linking it mate? I cant find it on the search
Old 04-12-12, 09:17 PM   #4
dkid
I used ratchet straps round the frame and over a roof beam in my garage. Pic shows the front end suspended (before I bought a headstock stand) but principle is the same for the rear end. Take off pillion seat and secure strap round frame.
Old 04-12-12, 09:17 PM   #5
Nobbylad
Nobbylad's Avatar
Used axle stands on the pillion pegs
Old 04-12-12, 09:32 PM   #6
Wildkid
I thin im guna need a bigger set of axle stands as mine arnt as tall as yours!
Old 04-12-12, 10:14 PM   #7
just take out the pins and turn the front pegs round and use axle stand under them
Old 05-12-12, 12:51 AM   #8
Got a car jack? Put the bike on the sidestand and undo, but don't yet remove, all the necessary nuts and bolts, then put the jack, (use a block of wood or similar), under the motor and lift it just enough to get the rear wheel off the floor. When you're done put it back on it's wheels before tightening everything back up.
Old 05-12-12, 07:00 AM   #9
Wildkid
Yeah I've got a 2 tonne trolley jack ? Will that be okay?
Old 05-12-12, 07:37 AM   #10
Fozzy
I used a ladder and straps.
Removed the pillion seat and looped the straps over the A framed ladder and then under the frame below the pillion seat. I used a second strap to prevent the lower part opening. Worked a treat.
Sent from my GT-I9100 using Tapatalk 2
curvy alternative rear wheel swap curiosity. MRedhead SV Talk, Tuning & Tweaking 14 03-11-11 04:18 PM
Alternative rear shock for a curvy? stew SV Talk, Tuning & Tweaking 15 10-04-10 09:10 PM
Alternative shock for SV650 eval k-neil SV Talk, Tuning & Tweaking 21 18-06-09 09:21 PM
Shock Swap Help jvdairlie SV Talk, Tuning & Tweaking 5 21-11-06 02:22 AM
Fitting Alternative Shock Jimmy2Feet SV Talk, Tuning & Tweaking 2 27-10-06 02:13 PM
