Old 02-01-13, 03:38 PM   #1
BradW314
Default Rough idle with new exhaust - Pointy.
I have a K5 2006 reg Sv650s so is fuel injection, today after fitting a new delkevic 200mm stubby exhaust I have noticed that the idle is now rougher (between 1400 and 1300) it used to be completely steady. It is also popping a bit more and is slightly harder to start. Could just be me being paranoid or they may be related. Any help would be great. Thanks very much.
Old 02-01-13, 05:16 PM   #2
Default Re: Rough Idle
Tricky one
Maybe your throttle bodies need balancing, which you didn't notice before fitting the new exhaust.
Popping might indicate that its not sealed properly on the link pipe?
Fitting an end can shouldn't affect anything like starting
There may be other more authoritative replies later by Pointy owners or those who know more about injection engine than me
Old 02-01-13, 10:21 PM   #3
BradW314
Hi there, thanks very much for your help, I checked the links and there is a couple of small leaks which I will put sealant on tomorrow
Old 03-01-13, 09:33 AM   #4
SV650Racer
Default Re: Rough idle with new exhaust - Pointy.
If the sealing doesnt cure your issues then it will be fueling. A 200mm can is considerably shorter than stock and can affect the fueling, generally by making the bike run rich. No two bikes will be affected the same and to the same degree either.
Id suggest a dyno run if it continues looking mainly at low speed/rpm fueling. Someone who knows what they are doing with a Yoshi box and an air fuel sensor on a dyno would be able to adjust the low speed. If you get stuck drop me a PM.
Old 03-01-13, 09:55 AM   #5
BradW314
Brilliant thanks just confirmed my thoughts, I'm sealing the links today and if that doesn't work I'm in contact with a bike garage for a dyno test. Thanks
Old 03-01-13, 11:40 PM   #6
BradW314
If I ran some injector cleaner through would that help at all?
Old 04-01-13, 08:17 AM   #7
Biker Biggles
Biker Biggles's Avatar
No.If the problem started after you changed the can then that is almost certainly where the problem is.
2006 Pointy running rough, now wont start. s7uyj SV Talk, Tuning & Tweaking 21 11-03-10 12:53 PM
rough idle husky03 SV Talk, Tuning & Tweaking 1 31-05-07 09:07 PM
2000 SV650 - sat in hot summer - now rough idle/slow speed randallp SV Talk, Tuning & Tweaking 6 19-11-06 08:41 PM
Rough Lumpy Idle SpankyHam SV Talk, Tuning & Tweaking 13 17-10-06 02:14 PM
popping exhaust at idle? toyotafj40s SV Talk, Tuning & Tweaking 5 21-08-06 01:31 PM
