Old 16-03-13, 08:06 PM   #1
Jason H
Jason H's Avatar
Default Renthal bars; longer cables needed?
So my handle bars may be a little bent as of half an hour ago(was surprised they bend so easily).
If I were to fit some renthals would I need longer lines?
J
Naked K5 - Now Red with sexy stripes!!
Mods: Renthal Flat bars, 's' clutch perch, GSXR front master cylinder, CNC shorty levers, Tail Tidy, Fuel Mini S/S Slip-on, 15/47, 's' Swing-arm, Pillion seat cowl, GSXR 750 front end, CNC polished top yoke, R6 Throttle tube, GSXR rear shock
Jason H is offline   Reply With Quote
Old 16-03-13, 08:18 PM   #2
Default Re: Longer cables needed
If yours is a naked, then probably not, but there a few different heights for Renthals
Old 16-03-13, 08:26 PM   #3
Jason H
Jason H's Avatar
It is indeed a naked. Was thinking med, low or ultra low. Depends on what I can get a hold of tomorrow tbh.
Is there anything else I should now about fitting renthals? Fitment of the controls etc?
J
Old 16-03-13, 09:05 PM   #4
I think all of them will be fine
You'll need to drill a hole in each side, as the switchgear has a locating pip. You can file it off, but then the throttle might spin round the bar
Old 16-03-13, 09:54 PM   #5
Jason H
Jason H's Avatar
You wouldn't happen to know off the top of your head what size said holes need to be?
If not I'll just have a look at the old bars.
Just a thought but if there is a pip in the switchgear, how does one go about removing them from the current bars?
Old 16-03-13, 10:01 PM   #6
Just check your old bars when you take the switch gear off, measure the hole until you get the drill sized nearest to the hole for the pip.
To remove the switches, just undo the screws and split the switch gear, the pip will come out of the hole easy enough
Old 17-03-13, 08:06 AM   #7
Jayneflakes
Jayneflakes's Avatar
I filed the little pip off and have had no problems with switch gear moving, which is lucky because I filed the little pip off ages ago before I realised what it was!
I also fitted Renthals to my pointy Sport and only needed slightly longer cables and lines, so I imagine that you will be fine.
Jayne you're a Pussy Magnet
naked top yoke on an S, longer cables? cyphertheory SV Talk, Tuning & Tweaking 10 12-05-11 07:43 AM
Renthal Bars BomBalong For Sale - Other Bikes and General biking items 2 24-04-11 08:18 PM
longer cables barwel1992 SV Talk, Tuning & Tweaking 2 17-10-09 09:45 PM
LOnger Cables and Izumo chains +tyres for France? ejohnh SV Talk, Tuning & Tweaking 4 18-03-07 09:29 PM
Longer cables for a SV650S kojay SV Talk, Tuning & Tweaking 4 09-03-07 10:03 AM
