Old 25-03-13, 07:45 PM   #1
sniff
sniff's Avatar
Default K series clock surrond
Anyone got one laying about they need to loose? Just the plastic which the clck sits in please.
sniff is offline   Reply With Quote
Old 26-03-13, 01:11 AM   #2
Binky
Emily Howard rides an SV
Binky's Avatar
Default Re: K series clock surrond
Firstly, what's a K series?
Secondly i've got a K2S clock surround you can have for postage.
Wowee Zowee
Old 26-03-13, 10:32 AM   #3
sniff
sniff's Avatar
K9 pointy. Sorry should have put pointy shoudn't I.
Old 26-03-13, 10:47 AM   #4
Geordie Mick
I've got a slightly damaged SK3 one if you're after a quick/cheap solution (left hand inspection panel absent and top right mounting lug broke off)?
MICK..
Old 26-03-13, 12:09 PM   #5
sniff
sniff's Avatar
chuck me a photo of the part please.
Old 26-03-13, 12:24 PM   #6
Geordie Mick
will do when I'm back from work tonight.
MICK..
Old 26-03-13, 09:09 PM   #7
Geordie Mick
PM'ed, mate.
MICK..
Old 27-03-13, 12:29 PM   #8
saucysaunders
Are you on about the bracket or the actual surround? I'm confused as you said the bit the clock sits in... Which would be the bracket
Old 27-03-13, 02:24 PM   #9
sniff
sniff's Avatar
One of these.
Sorry bout the size.
Old 28-03-13, 12:18 AM   #10
saucysaunders
Okay, I have one, but it has a hole cut in it to fit GSXR forks, so probably not of use to you. Sorry
V the new series vannus Idle Banter 2 05-11-09 07:58 AM
are all k series sz1 SV Talk, Tuning & Tweaking 5 08-10-09 09:41 PM
can you name this series Richie Idle Banter 21 16-03-08 04:57 PM
RST PRO series ejtrent Suits 3 18-08-07 05:26 PM
pointy clock cover(thingy on the back of the clock)!!!! ben650 Stuff Wanted 0 09-04-06 12:47 PM
