Old 03-04-13, 09:40 PM   #1
Littlepeahead
Littlepeahead's Avatar
Default Locksmiths : any on here?
Got home tonight and Stu's key has snapped clean off in the lock of the front door. Can't get the broken piece out. If anyone is or knows a locksmith who can give advice before I have to take a day off work I'd be grateful. Can PM pics.
Old 03-04-13, 09:46 PM   #2
Bluefish
Default Re: Locksmiths : any on here?
You have changed the locks on him haven't you? lol sorry, can you get some pick like things and tweeze it out, those metal scribes might work?
Old 03-04-13, 09:48 PM   #3
Littlepeahead
No. Too far in. I'll post a pic up.
Old 03-04-13, 09:50 PM   #4
Stuuk1
Some really sticky chewing gum on the piece of key you have left in your hand...?
Old 03-04-13, 09:54 PM   #5
Littlepeahead
http://forums.sv650.org/picture.php?...pictureid=6788
Old 03-04-13, 09:59 PM   #6
Richie
fantabulas
Richie's Avatar
paper clip with the tiny amount of 90 degree bend at the end and tease it out
My Flickr photos
Old 03-04-13, 10:02 PM   #7
svrich
Superglue (a very small amount) on the broken surface of the end you have? This happened on our old Discovery but I missed watching the bloke take it out as I made him a cuppa.
Old 03-04-13, 10:04 PM   #8
If you can return it back to center you might be able to use another key from other side to push remnants out.
There is little shuttle thing inside cam in middle of lock that will push it 1mm or so and might let you tweeze it.
If you got patience you might be able to grind some tweezers to get down parallel parts of key and grip it.
It won't come out twisted as it is because pins will hold it. Pins can only go up and down when barrel is in straight position.
Don't try sticky stuff you will only end up glueing lock solid
Old 03-04-13, 11:18 PM   #9
Nobbylad
Nobbylad's Avatar
Default Re: Re: Locksmiths : any on here?
Sharp drill, drill the barrel out and open the door. Bolt it on the inside of you can or screw it shut from inside for security until tomogs when you can get a new barrel from b&q.
Assuming you can get a drill from somewhere (garage/neighbours).
Old 03-04-13, 11:21 PM   #10
Nobbylad
Nobbylad's Avatar
You could always try ramming a screwdriver in there and turning it on the hope that the broken off bit will turn the pins.
Locksmiths Neeja Idle Banter 24 05-10-10 10:36 AM
