Old 09-04-13, 08:38 AM   #1
Pricey12
Default Kawasaki 636 BH1 rear shock bottom bolt part number?
Morning All
I will be getting hold of one of the above shocks in the next week or so - does anyone happen to know the part number for the bottom bolt that I will need when it is installed to my SV?
Thanks
Old 09-04-13, 09:03 AM   #2
Serdna
Default Re: Kawasaki 636 BH1 rear shock bottom bolt
Even with the part number i couldn't find it on line. I ended up going to a local mechanic who ordered the Kwak bolt in for me. Even with the correct bolt it will foul the dogbones if you don't shorten it. Unless i got the wrong bolt. If you are cutting the bolt be sure to put the nut fully on first, then after cutting when you remove the nut and it will clean the end of the thread nicely.
If you are messing around down there for the first time make sure you do it back up with a torque wrench and some medium locktite. There was a thread on here a few months back where a bolt was overtightened on the linkage and it cracked the frame.
Old 09-04-13, 09:12 AM   #3
Pricey12
I've had a read of some threads on here an it looks like there may be two different length bolts, depending on which year the shock is. I have a feeling I may have to find someone to fit the shock for me as I'm guaranteed to make a mess of it otherwise...
Old 09-04-13, 09:17 AM   #4
Serdna
Its not quite as easy as the threads on here make out I found(mostly due to the bolt cutting/spacing out the dogbones with washers fiasco), but its defo doable. If you can find an Organ with experiance who will help you, you will be fine. If you wanna come all the way to oxford I can help!
Old 09-04-13, 09:21 AM   #5
Pricey12
Default Re: Kawasaki 636 BH1 rear shock bottom bolt part number?
Thanks for the offer mate, but may be a bit far
May have to hold onto the shock for a bit when I get it until I figure out how to get it fitted.
Old 09-04-13, 09:44 AM   #6
jambo
jambo's Avatar
Order the parts for any ZX6R lower shock bolt between about 1998 - 2008 (I suspect up until current would be fine). I've installed 2 of these shocks in curvies and not yet needed to cut a bolt. You will notice if you put it in one way round it fouls, if you put it in the other it's fine (the distance from the shock bottom to the dogbones is not symmetrical).
Microfiche is here
You need parts:
92151-1601 BOLT,FLANGED,10X62
92210-1139 NUT,LOCK,FLANGED,10MM
Your local Kawasaki dealer can get these for you.
Jambo
Old 09-04-13, 09:50 AM   #7
Pricey12
Thanks Jambo
Help, I've screwed up the bottom shock bolt hongman SV Talk, Tuning & Tweaking 123 06-09-12 04:28 PM
Help! Someone else has (possibly) screwed up the shock bottom bolt! dirtyred619 SV Talk, Tuning & Tweaking 20 27-08-12 09:01 PM
Kawasaki zx636 c1h rear shock headrush1 For Sale - Other Bikes and General biking items 2 29-11-11 01:48 PM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
Anyone Know: Part number for a bolt? Kinvig SV Talk, Tuning & Tweaking 13 12-10-06 03:16 PM
