Old 25-04-13, 05:23 PM   #1
disco2
Default How much to fit fork seals?
Hi all I have a leaking fork seal.
This is not a job I can do myself as I do not have anywhere or the know how to do it I am mechanically minded but lack of space is a big problem.
So how much should I expect to be charged to supply and fit a new set of seals.
I know that different places will charge different amounts but im after a ruff idea please.
Also is it ok to still ride??? As I use it for work and need to use it for a while before getting it fixed.
Many thanks.
Old 25-04-13, 10:50 PM   #2
stuR
Default Re: How much to fit fork seals?
Id guess somewhere around £80-100 although not had it done myself. After all its gona cost them 1l of oil, the seals and then the labour. As for riding well its going to be a problem if its leaking alot if it gets on the disc n pads, otherwise youll just slowly change the suspension up front but i imagine it would have to be a pretty bad leak to get to that soon.
Old 26-04-13, 07:29 AM   #3
Doinitmyway
Doinitmyway's Avatar
I always fit genuine seals and, if flush enough, dust seals. Always do the pair aswell. £100 for the pair inc seals sounds about right as the seals can be 15-25 the pair and fork oil is about £10/l.
There is one place in Southend I can recommend but you have to prebook the work really. I can lend you a front headstock stand if you wanted to strip the forks out yourself and make it cheaper by just handing over the forks rather than a ride in ride out job?
Recetly did the set on my FZR250 after bursting one on a big pothole on Sutton road
Chris
10 GSX650F
95 BMW Funduro
89 FZR250R (x2)
92 RG80 (x2!)
89 AR125 - 89 RG125
75 CB200
Doinitmyway is offline   Reply With Quote
Old 26-04-13, 03:13 PM   #4
disco2
I think I have done mine on speed bumps on my way into work but have no choice but to go that way.
Pot holes are a pain I think some people must think im a nutter watching me wave all over the place trying to avoid them lol .
Where can you recommend then mate,
not fancy doing a set on an sv do you.
Replacing fork seals and fork set up? Ricky650 SV Talk, Tuning & Tweaking 11 26-03-12 02:20 PM
OEM Fork seals - where from? CodeJACK SV Talk, Tuning & Tweaking 5 07-08-10 07:47 PM
fork seals AndyBrad SV Talk, Tuning & Tweaking 7 29-05-09 08:21 AM
Fork oil seals, which way up? Ceri JC SV Talk, Tuning & Tweaking 5 04-03-09 07:33 PM
Fork Seals and Oil R11ysf SV Talk, Tuning & Tweaking 1 11-03-05 10:46 AM
