Old 02-07-13, 10:39 AM   #1
sniff
sniff's Avatar
Default Fairing wiring? Pointy.
OK I'm a little confused with some wireing on the K9S I've got two plugs on the front loom but only one place to plug this into. Can someone let me know where the top plug is supposed to go to please??
sniff is offline   Reply With Quote
Old 02-07-13, 10:40 AM   #2
sniff
sniff's Avatar
Default Re: Electrical plugs front end
This should have been the first.
Old 02-07-13, 12:11 PM   #3
sniff
sniff's Avatar
The connection block are all covered with black and white wires that are ground/earth wires.
The block is the second block below 2 which goes to the back of the clock.
Old 02-07-13, 01:04 PM   #4
smaller plug is an earth collection point and plugs into nothing (should have a cap on it)
bigger plug is main loom to headlight loom.
i need to see the smaller plug on the main loom but i suspect it's for the horn or one of the controls.
Old 02-07-13, 01:37 PM   #5
sniff
sniff's Avatar
I think I've found out what you mentioned. One plug is from the loom for all the lights. Other is just for earth leads and don't connect to anything.
Old 02-07-13, 01:38 PM   #6
correct
Old 02-07-13, 01:38 PM   #7
sniff
sniff's Avatar
This one is not connected to. Anything and need to go to Suzuki dealers in a moment so will see if I need a blanking connector to it.
Old 02-07-13, 02:36 PM   #8
Default Re: Fairing wiring? Pointy.
it does not connect to anything but it needs to have a cap on it in case of shorts as its the main return (earth) for the lighting circuit. it should also have a 'bridge plate/pins' on the top that connect all the 'earth' points together.
Pointy indicator relay wiring? Kilted Ginger SV Talk, Tuning & Tweaking 5 25-03-12 06:59 PM
Falcon Universal Fairing - Wiring Query amsvdaft SV Talk, Tuning & Tweaking 2 07-09-10 09:31 PM
Pointy SV650 ignition wiring pillphil Stuff Wanted 0 04-05-10 07:39 PM
Some wiring issues on my pointy de bong SV Talk, Tuning & Tweaking 16 13-10-08 10:55 PM
pointy wiring diagram suzook SV Talk, Tuning & Tweaking 4 14-02-06 08:08 AM
