Old 05-07-13, 04:05 PM   #1
Fallout
Fallout's Avatar
Default I is a profeshonal moocanik.
So got some cheap bolts for a suzuki moped calliper to replace my missing gixxer one. Figured there was a chance they'd be the same, and they only cost £1. Turns out they're too long, so that's no drama, I'll just angle grid off a few mm. See, I aint no cowboy!
Couldn't get a good grip on he bolt in my vice though, so wrapped it in a tie down strap. Nice and snug. Started grinding and things got hot. Bolt is glowing red! BURN BABY YEAH! End of bolt falls off as planned, but nylon strap burst into flames and welds itself to the bolt.
So I whip this flaming bolt out of the vice on it's nylon strap and look around for what to extinguish it with. The only liquid is petrol, so I figured that was a bad idea. Ran outside into the garden and start spinning this flaming nylon chord around my head. "GO OUT YOU *******!" I scream.
Nylon strap burns through, flaming bolt flies across garden towards dog. Dog ****s itself and runs into glass door. I laugh, pick up bolt, hot potato juggle it into the garage, peel off the cooling nylon, then try it out on the calliper. Perfect fit!
So I've learnt my lesson! If I accidentally set fire to something, try to put it out with petrol anyway, even if it seems silly, otherwise I might scare the dog. Mechanical XP +1.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 05-07-13, 04:07 PM   #2
Default Re: I is a profeshonal moocanik.
class
Old 05-07-13, 04:40 PM   #3
Paul the 6th
Paul the 6th's Avatar
cowboy level: Hi ho silver... heehaw
Old 05-07-13, 04:41 PM   #4
lol! nice one
Old 05-07-13, 04:49 PM   #5
stuR
Hack saw then smooth the ends with a grinder works a bit better
Old 05-07-13, 04:53 PM   #6
wideguy
Possibly you ruined the strength of the bolt by heating it up so much. Maybe not.
Old 05-07-13, 06:01 PM   #7
Lozzo
I'd have let it burn itself out then peeled the melted plastic off.
Old 05-07-13, 07:43 PM   #8
Fruity-ya-ya
Classic.
Old 05-07-13, 08:49 PM   #9
Fallout
Fallout's Avatar
The hacksaw didn't even occur to me! My mind went instantly to the angle grinder when I realised I was out of dremmel cutting discs. Typically I only use a hacksaw when removing brake lines I've snapped as a result of not attaching the calliper to the bike at all.
Old 05-07-13, 09:01 PM   #10
The Idle Biker
Brilliant. Have some spare K1 Gixxer caliper bolts you could have had for nothing though. Just saying.
