Old 09-07-13, 07:48 PM   #1
Nutsinatin
Nutsinatin's Avatar
Default Holed radiator.
Anyone had worse luck when they bought an SV? Second owner on a 2009 model with full suzuki service history (had 7000 miles when I bought it), I've done 3000 miles and so far have burnt out the ignition circuit with water in the connector block, then a rear wheel puncture with 400 miles on a new tyre, then burnt out headlight circuit due to water in the connector block and today I holed the radiator when a stone went through it. I live in the middle of nowhere (hour walk to the train station - no other public transport) so I'm now stuck with a two hour commute to Reading when a return train ticket costs the same as half my weekly fuel bill whilst I try to repair the bike (good luck getting a rad, gotta get one posted as I can't pick one up!) and as I just started a new job Monday I won't get paid now until the end of August. Someone cheer me up please!
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 09-07-13, 08:14 PM   #2
Spank86
Default Re: Vent
stick chewing gum on the rad?
Old 09-07-13, 08:34 PM   #3
Nutsinatin
Nutsinatin's Avatar
Default Re: Vent
What harm can it do? Think it would be alright to just use water in it to go get some coolant?
Old 09-07-13, 08:58 PM   #4
Biker Biggles
Biker Biggles's Avatar
Default Re: Vent
Plain water is fine as long as it stays in and doesnt p1ss out while you are going along.Race bikes run with just water all the time.
Old 09-07-13, 11:32 PM   #5
rapidgaz
rapidgaz's Avatar
Default Vent
Bet they use distilled water, unless its very soft water where you live. Hard water is not good for alloy engines.
rapidgaz is offline   Reply With Quote
Old 10-07-13, 06:33 AM   #6
Biker Biggles
Default Re: Vent
For a day or so while you fix it?Im sure any old water will be fine as long as it doesnt have lumps in it.
Old 10-07-13, 10:23 AM   #7
Scoobs
Default Re: Vent
Nice one Spank.
I had to do this when I holed my rad when I was out with the GM hooligans
Got me home and I then cleaned it all off with copious amounts of WD40. Flashed all that off with brake cleaner then smeared some 2 pack epoxy over the hole. That was a couple of thousand miles ago. Doesn't leak and cost about £4.99 to fix.
Old 10-07-13, 12:50 PM   #8
wideguy
Default Re: Holed radiator.
What Scoobs said. If you take your radiator to a repair shop, they'll do basically the same thing, they'll just charge you for their expertise.
Old 10-07-13, 05:24 PM   #9
Nutsinatin
Nutsinatin's Avatar
Well I'll give it a go as Suzuki want £500 for a new rad and see how it holds out, makes me feel slightly better!
Sk6 Radiator joshwalker094 Stuff Wanted 1 24-01-13 11:15 PM
radiator cap braders Stuff Wanted 0 31-01-11 07:27 PM
Radiator cap FOO Stuff Wanted 7 01-02-10 10:10 AM
Radiator K5 hindle8907 Bikes - Talk & Issues 8 17-12-09 02:05 PM
radiator cap?? ben650 SV Talk, Tuning & Tweaking 2 14-03-07 11:38 PM
