Old 18-07-13, 07:54 PM   #1
chris c
Default Chain noise?
Hi Guys
Whilst lubing the chain today on the paddock stand i noticed that when i rotate the back wheel i can feel a slight notch type feeling in the rear wheel and at the same time to can see the chain ping/click like somebody's flicked it. You can feel it when you push the bike but not when you ride it?
it does it every few mm of wheel rear travel, i cant see any tight spots in the chain and its well lubed. The only thing i can notice is slight wear on the front sprocket
It concerns me to ride it now ive noticed it incase the chain snapps or something messy like that!
Old 18-07-13, 10:19 PM   #2
Default Weird chain problem
Not unusual. The sprockets are worn and the teeth are no longer shaped perfectly correctly. Put the bike on a paddock stand turn the wheel backwards, thus putting the tension in top run of the chain - as it is when the engine sprocket is driving the bike along - noise reduced? If yes then it's not worn out yet.
Weird electrics problem ranathari SV Talk, Tuning & Tweaking 3 02-11-10 06:51 AM
Speedo problem - weird one. dmracing SV Talk, Tuning & Tweaking 7 22-04-10 08:29 PM
Weird Problem kenada SV Talk, Tuning & Tweaking 7 06-10-09 01:09 PM
Weird Problem, Electrical mister c SV Talk, Tuning & Tweaking 8 15-12-08 11:26 AM
Weird Problem lynw SV Talk, Tuning & Tweaking 5 15-06-06 08:01 PM
