Old 30-08-13, 05:03 PM   #1
rapidgaz
rapidgaz's Avatar
Default Pointy rear jack up?
Hi guys and gals, was thinking about jacking up the back end of my pointy to an extra 30 mm with shorter dog bones.
A. Will it make my suspension harder or softer
B. will it make the handling worse or quicker
Or will it do absolutely nothing.
Cheers guys.
rapidgaz is offline   Reply With Quote
Old 30-08-13, 07:13 PM   #2
svsam
svsam's Avatar
Default Re: Pointy rear jack up.
I got 45mm jack up dog legs on my sv, it handles great, turns in a lot sharper, though I do have the forks dropped through 5mm too! Cant really say I noticed any difference in the stiffness of the spring but I do ride with a pretty hard setup anyway.
Give it a go, you can always change back.
Sent from my GT-I9195 using Xparent BlueTapatalk 2
SL0 jack up kit-yoshimura can-tial tidy-(so far)
svsam is offline   Reply With Quote
Old 30-08-13, 07:16 PM   #3
rapidgaz
rapidgaz's Avatar
Default Pointy rear jack up.
Ordered will see what they are like. Paid 18 quid does that sound about right.
Old 30-08-13, 09:41 PM   #4
Runako
I take it you have the stock shock? Raising the rear changes the steering geometry. Yes quicker to steer but not necessarily better to ride. That depends on your weight in relation to the spring and things like sag. So if the intention is to use the shorter dog bones option as a way of improving the bike, I'd suggest you start by improving the components that affect handling and ride the most (i.e. better shock / fork components, better tyres etc). Set up your sag and then once you've fine tuned these things you can more easily tell whether changing the ride height geometry is a good or bad thing.
Old 31-08-13, 12:16 AM   #5
rapidgaz
rapidgaz's Avatar
Will be bit by bit. Just not got bottom less pockets at moment.lol
Trying to get it to stay more weight forward when otherhalf is on the back really. Was hoping it would help in that area. Will try when they come. Looks pretty easy job to do.
Old 31-08-13, 04:15 PM   #6
rapidgaz
rapidgaz's Avatar
Got my jack up dogs. Seems ok at the moment. Will know more when I go out for a thrash without the other half on.
Old 31-08-13, 07:31 PM   #7
lawson17
Do you change your preload when riding with a pillion?
Old 31-08-13, 08:26 PM   #8
i might have this the wrong way round but reducing the length of the dogbone increases the rising rate so you end up using less force and distance to move the stroke of the damper rod in the shock.
Old 31-08-13, 09:08 PM   #9
Nutsinatin
Nutsinatin's Avatar
From my experience with pillions until I firmed up the forks I couldn't crank up the rear preload much as the front just dive bombed any time I braked or even rolled off some throttle. But as you said that costs more than dogbones!
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 01-09-13, 01:46 AM   #10
rapidgaz
rapidgaz's Avatar
I have my front pre load at max and rear 2 notches before max. But don't change between taking her and not. She makes me ride very sensibly. Lol
Rear jack up and soft front suspension. NeoIce SV Talk, Tuning & Tweaking 5 23-04-10 10:24 AM
Jack Ups & Rear Sets TheStudent SV Talk, Tuning & Tweaking 15 08-11-09 09:27 PM
Rear end jack-up kit, anyone help? mattyL SV Talk, Tuning & Tweaking 9 02-04-07 05:23 PM
Rear set jack up plates svrash Stuff Wanted 2 05-07-06 08:32 AM
Jack up my rear end!!!!!!!!!! gc350 SV Talk, Tuning & Tweaking 0 18-08-05 12:25 PM
