Old 20-10-13, 10:22 PM   #1
Ninthbike
Default Stainless replacement exhaust clamps?
The front downpipe has been bothering me since I got the bike (I thought the gasket might be blowing at the head) so decided yesterday to give it a good clean. This would mean removing the belly pan. It didn't take long to discover that all of the retaining screws had mashed-up hex sockets. Two came out with a bit of elbow grease and WD40 but the other two were stuck so I removed the brackets from the mounting points. All of the brackets are rusted to buggery so will ultimately need replacing but I had to drill the head off one screw and get the other (just) with a pair of mole grips. Replaced all screws with stainless ones and installed with copper grease. This is a genuine Suzuki belly pan which currently retails for circa £300. It was bought by a previous owner in 2009 so has been on the bike for about 4 years. I cannot believe that the brackets are so fragile for something that costs so much but am also really disgusted that the previous owners have let it get into such a state. Have now cleaned belly pan and got to work on the downpipe with sanding pad and wire wool/Solvol and it looks much better. Also cannot believe that Suzuki are still putting mild steel clamps on stainless exhausts - the front one is almost rusted away. Anyone recommend a stainless replacement? Braided hoses on the way and it looks like it could be a busy winter.
Old 21-10-13, 12:52 PM   #2
wideguy
Default Re: Stainless replacement exhaust clamps?
I recently bought a stainless t-bolt clamp from a local (to me) hydraulic hose supply outlet. All types and sizes of hose and clamps available at such places.
Old 21-10-13, 12:56 PM   #3
Nobbylad
Nobbylad's Avatar
http://www.ebay.co.uk/itm/Mikalor-W4...item1e6769c6d9
Old 21-10-13, 05:18 PM   #4
Ninthbike
Cheers mate. Is that the correct diameter for where the downpipe meets the collector?
Old 21-10-13, 07:40 PM   #5
Nobbylad
Nobbylad's Avatar
Sorry fella, I have no idea. Pretty sure there's a post detailing which size is right but I can't be bothered searching
Old 21-10-13, 08:02 PM   #6
admin
John T
admin's Avatar
Have a look at the main site in the articles section. See diary of an SV restorer. I used Mikalor clamps on my pointy and curvy. I'm sure I mentioned sizes there.
sent via carrier pigeon.
Old 22-10-13, 04:03 PM   #7
embee
embee's Avatar
I've found stainless Mikalor items, clamps and P-clips etc, to be nice quality. Happy to recommend.
Old 22-10-13, 05:45 PM   #8
The marine grade ones are even better than the normal one. Cost a little bit more mind
Old 22-10-13, 08:08 PM   #9
admin
John T
admin's Avatar
Yes, I used the marine grade too.
Old 23-10-13, 12:55 PM   #10
w4 is marine grade. w5 might stay slightly shinier being 316
Maintenance course I've been on Winder Idle Banter 7 24-03-12 10:18 PM
Maintenance Bill.Cross SV Talk, Tuning & Tweaking 3 07-03-09 10:02 PM
poor visability (or just poor knowledge) gdharbourne SV Talk, Tuning & Tweaking 5 03-12-07 09:39 PM
Maintenance? catchsomesv650 SV Talk, Tuning & Tweaking 20 17-08-07 10:58 PM
SV Maintenance Draper Bikes - Talk & Issues 6 21-05-07 10:27 PM
