Old 07-12-13, 04:37 PM   #1
stuR
Default Polishing up those old headlights - link to guide
My girlfreinds car headlights were yellowing/clouding up slightly so i thought id have a look and see what i could do. A mate showed me this guide which was quite useful.
http://www.mk5golfgti.co.uk/forum/in...?topic=26433.0
I didnt quite follow everything the same, i used:
1200 wet n dry, then 2000 wet n dry, then 2500 wet n dry
Then i used a DA polisher with a sponge pad and some fine cutting compound, then after i used the DA again with some ultra shiny polish. After all that i finished it with wax on top. Her lights took me approx 1 hour each side, and the result was well worth it. Heres a pic with the left hand side done and the right not yet touched.
http://imageshack.us/photo/my-images/69/r69u.jpg/
The end result was that the lights looked 90% brand new. If you inspect them, theres still some light scratching but this could have been fixed if i wanted to spend ages on each one. As it is, they look brand new from about 2 feet away so it was a good enough result for me.
Thought it was worth a mention for those with bike or car lights needing a refresh..
Old 07-12-13, 04:44 PM   #2
Default Re: Polishing up those old headlights - link to guide
I've got a 3M Headlight Restoration Kit sitting here that I will be using on my car headlights. The results make the lights look brand new. I'll probably wait and do it after winter now though
Old 07-12-13, 05:53 PM   #3
stuR
Doesnt look a bad kit if you dont have any of the bits, but i had it all already other than £8 of sandpaper.
Old 07-12-13, 10:06 PM   #4
Mikey360
I remember reading somewhere that toothpaste does a pretty good job?
Old 07-12-13, 11:20 PM   #5
stuR
I had read the same before but apparently not compared to sandpaper, unsurprisingly
What's best for polishing? Nobbylad Bikes - Talk & Issues 2 27-02-10 01:01 PM
Polishing my can...... davidimurray SV Talk, Tuning & Tweaking 14 26-09-07 03:22 PM
Polishing _Stretchie_ Photos 13 07-02-07 10:52 AM
Polishing alex.j SV Talk, Tuning & Tweaking 7 16-02-06 02:03 PM
Polishing pencil shavings SV Talk, Tuning & Tweaking 8 10-01-05 11:59 PM
