Old 12-01-14, 08:00 PM   #1
mglinak
Default Rear Brake Pedal Seizing Up
Rear Brake Pedal on my K8 SV seizes up with depressing regularity. I've become quite good at sorting it but has anyone else had the same problem and found a longer lasting solution?
Old 12-01-14, 09:17 PM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: Rear Brake Pedal Seizing Up
The long term solution is to remove it from the footrest and clean up the crud from the bits that rotate with emery cloth or similar.Then grease it up and reassemble.The shortcut is to squirt some penetrating oil around the pivot and hope it creeps in the right place.
Old 13-01-14, 08:44 AM   #3
Do a search - covered a number of times, with a full long term fix written up.
Old 13-01-14, 05:41 PM   #4
mglinak
Tried the above on a number of occasions. Still seizes up - search of forum did not come up with any better idea
Old 13-01-14, 06:25 PM   #5
JulesW
JulesW's Avatar
I find the search function next to useless, I must be using it wrongly because I usually get pages of irrelevant garbage to sift through.
Bikes I've owned and loved:
Bridgestone 90, Honda CB175, Suzuki GT250, Yamaha YZ125, RD350LC x2, RD350YPVS x2 & FZR600, Honda CB900F, Suzuki SV650S K6, 2014 Triumph Street Triple R
JulesW is offline   Reply With Quote
Old 13-01-14, 07:09 PM   #6
The problem is likely this:
Originally Posted by Me!
Remove the lever from the footrest and remove the fibre bush from inside the lever *very carefully* - the bush isn't available separately and it's easy to damage - if you look close you can see where the bush is split, gently get behind it and roll it up a little you'll be able to pull it out, if you look inside the lever you'll see where corrosion has built up behind the bush, expanded, and squeezed the lever onto the footrest pivot, causing it to drag, if you gently scrape away the corrosion smear the area with a little grease so it doesn't corrode so easily and reassemble it should be fine.
Curvy brake lever & rear brake pedal Old Git Stuff Wanted 1 09-01-10 11:00 AM
99-02 rear brake pedal Marcus Stuff Wanted 17 14-04-09 07:27 PM
Rear Brake Pedal 01 sv650s Stuff Wanted 1 29-03-07 10:11 PM
Rear Brake Pedal 01 sv650s Stuff Wanted 0 29-03-07 07:59 PM
Rear Brake Pedal teknovision2 Stuff Wanted 1 24-07-06 06:21 PM
