Old 16-01-14, 10:15 AM   #1
reidy
Default Cam chain replacement?
Hi guys, I've just put my Sv into a mechanic to check out the common sv rattling sound and found out that the tensioners are fine but the cam chain needs replacing, I know usually you change them in pairs ........ but looking at the prices for cam chains I keep seeing quotes for near £100 for one chain alone this was on more than 1 website as well surely this can't be right or am I looking at the wrong part ?
any help appreciated guys
Old 16-01-14, 10:21 AM   #2
Default Re: cam chain replacement
The labour will make your eyes bleed, it's a cnut of a job. Are you SURE? How many miles has it done? Are you absolutely positive the camchain has excess play in it?
Old 16-01-14, 10:28 AM   #3
atassiedevil
Personally i'd suspect the tensioners, rather than the chain. To put that much stress on a chain to stretch it to that degree...Yours is a curvy too. There are known cam tensioner issues from the earlier models.
See this thread here....
http://forums.sv650.org/showthread.php?t=129497
Old 16-01-14, 10:35 AM   #4
The problems with the early tensioners 99.9% of the time is just rattle of a sleeve inside and harmless. Lots of people (me included) were very paranoid about it at the time thinking it was actual camchain noise but it wasn't.
Old 16-01-14, 11:12 AM   #5
Under normal circumstances you really need to put a lot of miles on an SV to wear out the camchains, two 100,000 mile SV engines I know personally are still wearing the original chains, both have had the tensioners replaced, one engine twice over.
It can happen of course, but it's rare enough that I would check very, very carefully to make absolutely certain it were needed before going further.
Old 16-01-14, 01:12 PM   #6
prokartman
prokartman's Avatar
Default Re: Cam chain replacement?
I have just had both my cam chains replaced and all 8 valve shim's done at the same time ( both my adjusters were nearly at their maximum length , just a couple of notches left to go ) . The work was carried out by Galea Cam Chain Services and came to £335 in all .
This was on a SK6 with 37k miles on it . They don't strip the engine but do the chains like you do a drive chain ( use the old one to pull the new one through ) then rivet link it together , this saves massively on the labour cost . Most dealers would charge this much for the shim job alone ( maybe more ) .
Just to make it clear , I have no connection or financial interest in Galea Cam Chain Services other than being a customer of their's . Also I had already removed the radiator and airbox to save on the labour costs .
prokartman is offline   Reply With Quote
Old 16-01-14, 01:21 PM   #7
The stock ones last over 100k except in unusual circumstance (nobbylad ex fizzwheels missus pointy for example... one chain was fine... tother one had about8mm of play in it?!)
I wouldn't change them cos of a few clicks left either, I'd wait for the rattles, a few clicks might be longer than you keep the bike.
Mine's on 105k, a lot of those miles for example with silly gearing, sat on the motorway kissing the limiter for a tankful of juice at the time. Nowt wrong with the camchains though.
Old 17-01-14, 10:42 AM   #8
muzikill
muzikill's Avatar
I think yorkie is trying to say '2nd opinion it' tbh. This garage you took it to, was it an official suzuki garage?. If not, would they specifically know the bumps & niggles on these bikes depending on the year of build?. If theres a suzuki garage near you i dont see any harm riding it in and getting one of the engineers to have a listen & just getting a diagnosis under the pretence of a possible repair quote just to put your mind at rest before this other garage start stripping it to bits when it's not necessary.
Sv650 chain replacement. muzikill SV Talk, Tuning & Tweaking 0 05-05-13 03:18 PM
Cam chain replacement - is that normal? Knaapie SV Talk, Tuning & Tweaking 19 09-11-08 10:27 PM
Do I have to take off the swing arm for chain replacement? budrosmith SV Talk, Tuning & Tweaking 18 29-01-07 06:57 PM
Replacement Chain and Sprockets sharriso74 Idle Banter 7 22-05-06 11:51 AM
chain and sprocket replacement sv650gerbrit SV Talk, Tuning & Tweaking 5 11-05-06 09:48 AM
