Old 04-02-14, 03:18 PM   #1
Regrin
Default Pointy STV starting position?
Hello, new here but had sv650 for a while. I am having trouble starting my bike after a month of being laid up. My question is what position should the secondary throttle butterflies be in after you have switched on and they have cycled? Thanks in advance!
Old 04-02-14, 03:44 PM   #2
jambo
jambo's Avatar
Default Re: Butterflies
I'm not sure. However, if you were to start with which year and model of bike you have, what is and is not working (does it turn over, are there any error codes on the dash, have you checked for a spark), we may be able to get you sorted.
Jambo
Old 04-02-14, 10:06 PM   #3
Cymraeg_Atodeg
I am guessing if they are questioning secondary throttle butterflies it is a "pointy"
It's a bit worrying if it is causing issues after a month, my SV1000S has sat for four months and I know she'll start first time.
Old 06-02-14, 08:41 AM   #4
Default Butterflies
They don't "cycle", when cold they will open a tiny bit as they operate the fast idle cam. If it's an early Pointy that is - like Jambo said it would help if we knew a bit more specifically which model it is.
54mm Throttle body butterflies... ThEGr33k Bikes - Talk & Issues 2 18-04-09 09:37 AM
