Old 08-02-14, 10:42 PM   #1
sv650kent
Default Spark plug location? K7.
trying to change my spark plugs, my model is a 2007 fully faired sv650.
i have been told that the 2007+ models have four plugs but i can only locate two
one in the front and one in the rear.
can anyone help
Old 08-02-14, 10:44 PM   #2
Tomor
Tomor's Avatar
Default Re: help with spark plugs
I believe the other two are on the side of the cylinder head.
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 08-02-14, 10:46 PM   #3
sv650kent
i was following this http://bolty.net/2009/10/06/how-to-c...in-your-sv650/ but it just doesnt look the same.
Old 08-02-14, 10:51 PM   #4
Tomor
Tomor's Avatar
The pic at step 3 show the front two plugs. Have you done those two?
Old 08-02-14, 10:53 PM   #5
sv650kent
no as i say the pic does not match what i have. almost like its different engine.
i can only see one plug when i move the radiator and one under the coolant system
Old 08-02-14, 11:02 PM   #6
Tomor
Tomor's Avatar
You may have a late registered 2006 (K6) engine then, They only have 2 plugs. If you cant see a plug there, there isn't one any you are done!
Old 08-02-14, 11:04 PM   #7
sv650kent
cheers, just wanted to check i was not being a fool
Old 08-02-14, 11:12 PM   #8
Tomor
Tomor's Avatar
If there are only two plugs, how can you change 4?!
Old 09-02-14, 03:55 PM   #9
madcockney
With anticipation
madcockney is offline   Reply With Quote
Old 09-02-14, 04:16 PM   #10
sv650kent
Default Re: Spark plug location? K7.
I was only asking as the forum says 2007+ has four plugs. Mine is meant to be a 2007 but only has two visable plugs. Either I got conned and the engine has been replaced to a older model or I got a 2006 with a late registion .
Spark plug cap won't fit ChrisCurvyS SV Talk, Tuning & Tweaking 9 18-11-13 09:26 PM
Spark plug - what's the gap? tom-k6 Bikes - Talk & Issues 4 24-03-12 09:23 PM
Spark plug as sump plug? Nobbylad SV Talk, Tuning & Tweaking 25 21-02-11 12:45 PM
Spark plug question skyline SV Talk, Tuning & Tweaking 12 06-08-09 06:00 PM
HELP! spark plug problem heedbaw SV Talk, Tuning & Tweaking 7 23-10-07 02:36 PM
