Ancillaries Post your own reviews, opinions and experiences on various other bits and bobs, such as rearsets, oil, engine bits.
Old 24-02-14, 07:20 PM   #1
Gary1966
Default after market levers on a 2010 model
Well after fitting new levers to my suzuki sv650 and taking it out for its first run yesterday I found I had a problem. There is a Micro switch for the clutch lever to activate which was no longer working, basically the bike won't start without the switch being in the "out" position. This wasn't an issue as the new lever didn't have a tab to hold the switch in. However the bike began to stall when pulling the clutch in, huh!
A quick scout on the sv650 forum and it appears the micro switch sends a signal to the engine management system and this somehow dictates the revs once it's pulled in?
Anyway a little bit of thinking and I came up with this. The old lever is on the left clearly showing a large "tab" to activate the switch. A 3mm hole was drilled in the new lever,
I then shaped a stainless rivet and looped the end so there was a good contact point to push the switch. Epoxy resin bonded into place and a small piece of black shrink wrap and "voila" job done.
Hopefully this is the stalling issue and only time will tell now if it solves the problem. The bike has been fine up until fitting the levers so it does seem significant.
Old 24-02-14, 07:25 PM   #2
Gary1966
Default Re: after market levers on a 2010 model
Old 24-02-14, 10:34 PM   #3
Tomor
Tomor's Avatar
My Chinese levers came with a tab similar to the original lever to make contact with that switch. You sure your levers are for your model of bike?
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 24-02-14, 11:15 PM   #4
never had a problem with the many sets of levers i have had from china. but i only buy from one place 'the2wheels'.
Old 25-02-14, 07:24 AM   #5
Gary1966
Yes i must admit i was surprised, they were from China and i did state the model year , must have just been unlucky
Never mind though problem solved
Old 25-02-14, 03:53 PM   #6
zippie01
I have bypassed my clutch switch, they are prone to failing and cost £10 a pop !!
Old 25-02-14, 04:22 PM   #7
Tomor
Tomor's Avatar
Is your bike FI Zipple?
Old 25-02-14, 04:56 PM   #8
zippie01
FI ???
zipple ??? ha ha ha
Old 25-02-14, 05:39 PM   #9
Tomor
Tomor's Avatar
Sorry couldn't remember your forum name as on my phone and it didn't show it! FI is fuel injected (k3) onwards.
Old 25-02-14, 07:01 PM   #10
PyroUK
PyroUK's Avatar
My chevers were from the2wheels and I have the tab missing too! Bloody pain in the r's!! Went to go start bike for work and it would go.
Seems like a reasonable fix for the issue!
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Shorty levers for 2010 sv650s PyroUK Stuff Wanted 17 30-05-13 04:27 PM
bypassing clutch switch and side stand on 2010 model? cmjhs SV Talk, Tuning & Tweaking 7 19-10-11 09:09 AM
Carlsberg rideout 2010... 16 MAY 2010 it is then ! Paul the 6th Pennine Massive 80 19-04-10 09:38 AM
Curvy Carbs, clutch levers and brake levers 21QUEST For Sale - SV's and SV related items 2 03-03-10 11:04 AM
After market levers (gsxr) scottjames Bikes - Talk & Issues 3 16-10-09 11:31 PM
