Old 20-05-14, 08:26 AM   #1
stranger12
Default SV650 K5 - which suspension oil?
Hi All,
time to change my sv650 oil. I have never done this before.
is it the same oil as the engine oil ?
I have seen forum mentioning 5w for light weight and 10w-15w for heavy
please suggest .
If my suspension has a soft spring and I use 15w which reduce dampening is that the same as having stiffer spring ?
i am 110kg and plan to use my bike in track days only
The reason for not changing the spring is I don't know what type of spring rate I have .
I am thinking of taking it off first and then testing to find out its rate
Old 20-05-14, 08:55 AM   #2
jambo
jambo's Avatar
Default Re: sv650 suspension oil
If you weigh 110kg, it's a fair bet that the standard springs will be on the soft side.
Work out what spring rate you're after using something like the racetech calculator: http://racetech.com/ChooseVehicle.aspx (you don't mention the year for bike you have, but the spring rate will be similar in either case).
Get the spring right first, and for something that stiff, on track I'd probably start with a 15w and see if that was too choppy or not.
Spring rate will affect how far the suspension travels for a given load. Fork oil viscosity will affect the rate that the forks bounce back up after being compressed (standard forks have very little compression damping, you can look at emulators if you want to change this).
Jambo
Old 20-05-14, 09:07 AM   #3
stranger12
Default Re: SV650 - which suspension oil?
thanks
my bike is 05 model
the previous owner has installed braided brake lines and crash protectors plus some other race modes so thought he should have changed the spring but that is dependent on his weight . if he was 50-60 kg then I have a wrong spring in there.
I am going to take the spring out, is it a difficult task ?
re oil is it the same engine oil that everyone uses ? or specific fork oil ?
Old 20-05-14, 09:16 AM   #4
JulesW
JulesW's Avatar
You'll need oil specific to forks i.e. Fork Oil
Bikes I've owned and loved:
Bridgestone 90, Honda CB175, Suzuki GT250, Yamaha YZ125, RD350LC x2, RD350YPVS x2 & FZR600, Honda CB900F, Suzuki SV650S K6, 2014 Triumph Street Triple R
JulesW is offline   Reply With Quote
Old 20-05-14, 09:40 AM   #5
jambo
jambo's Avatar
Originally Posted by stranger12 View Post
thanks
Not really. Get the weight off the front end (NWS/Abba stand and a jack at the front / tie downs at the rear or similar). Undo the top yoke clamps where they grip the top of the fork, then undo the fork cap itself. Pull out the spacers & springs. If you've got after-market ones sometimes they have the rate etched onto one end. Depends who made them.
As above, it's a specific fork oil. And different manufacturers class weights differently, there's a table here that's worth a quick glance. Don't get too hung up on it, just appriciate that if you want to change oils around for feel it's best to stick with one brand where possible as some 10w are thicker than other's 15w. This can get very confusing if you move from a 10w to a 15w and it feels the same
Jambo
Old 21-05-14, 01:16 PM   #6
stranger12
many thanks
SV650 suspension improvements? stranger12 SV Talk, Tuning & Tweaking 17 29-04-14 08:12 AM
sv650 suspension sag stranger12 SV Talk, Tuning & Tweaking 3 11-10-13 08:52 AM
Sv650 stiff front suspension? stranger12 SV Talk, Tuning & Tweaking 7 03-06-13 01:22 PM
sv650/s suspension questions barwel1992 Bikes - Talk & Issues 32 29-09-09 12:22 PM
Front suspension of a SV1000 on a SV650 JanGoris SV Talk, Tuning & Tweaking 3 10-04-06 10:10 PM
