Old 28-05-14, 04:21 PM   #1
ophic
ophic's Avatar
Default Rapid clutch wear
I adjusted my clutch lever about 2 weeks ago as I was struggling to get neutral and I thought it might be dragging a bit. There was quite a lot of slack movement at the outside of the lever travel, so I adjusted it so there was nearly none.
So now 2 weeks later, it's pretty much back to how it was before the adjustment. Now I realise that London commuting will wear the clutch a lot more than the long motorway commute I used to have up north, but this seems a bit excessive. I don't ride like a hooligan but I don't dawdle either.
So, is my clutch about to die? Bike has about 40000 miles on it and it's the original clutch.
It's an SV650SK3.
Silver SV650SK3, Fuel exhaust
Old 28-05-14, 04:42 PM   #2
davepreston
Default Re: Rapid clutch wear
oil level effects the clutch bruv are you "in the zone" with your levels
Old 28-05-14, 05:21 PM   #3
try adjusting at the worm gear mechanism.
is the lever adjuster where it was the last time you set it? the lever adjuster can vibrate back in.
Old 28-05-14, 06:05 PM   #4
ophic
ophic's Avatar
Oil is fine and hasn't changed in the past 2 weeks. The adjuster was more or less where it was after I last set it - it might have moved a bit but not much. The cable is either slipping, stretching or the clutch is wearing. Although, which direction would the clutch wear? I'd think it'd wear to the slip side rather than dragging.
Sent from my Nexus 7 using Tapatalk
Old 28-05-14, 06:41 PM   #5
how stiff is your clutch cable, might be time for a new one.
check the condition of the worm gear, it might be on its way out/seizing up.
Old 28-05-14, 07:03 PM   #6
jambo
jambo's Avatar
As someone who's done the London commute thing for a number of years, it won't cause the clutch to go out of adjustment every few weeks. It will, however, increase wear to the lifter mechanism. I'm on the original clutch plates at 60,000 or so miles. But the lifter had been replaced once already and I think it's due again.
The cable itself can't slip add it's held firm at both ends, but the 2 slack adjusters can move if not tightened up properly, and any wear in the lifter makes finding an adjustment without any drag much harder
Jambo
Sent without a real keyboard
Old 28-05-14, 07:53 PM   #7
Red ones
Red ones's Avatar
Sounds like classic worm problem.
Do a proper clutch adjustment, check the knurled adjusters at the lever aren't coming loose etc. but at that mileage I certainly wouldn't rule out the worm.
I did 100,000 miles of London commuting over 8 years and the clutch plates were still fine.
Old 28-05-14, 11:40 PM   #8
I'll put an entire quid on the lever end adjuster rattling loose. Give the lock ring a tweak with a pair of pliers to make sure it stays put.
Old 29-05-14, 12:03 AM   #9
davepreston
tight barsteward
that wouldn't even buy a half round your way
Old 29-05-14, 06:50 AM   #10
Half of what? A KitKat, sink plunger, dead mouse or what?
loctite 518 rapid responce needed. Owenski Hardware 10 27-02-11 07:01 PM
rapid flashing indicators - yet again. malongworth SV Talk, Tuning & Tweaking 11 19-06-10 11:55 PM
Automatic choke rapid fall off? gedcarney SV Talk, Tuning & Tweaking 2 31-03-09 11:42 AM
Rapid Training Stu Bikes - Talk & Issues 0 25-01-08 05:55 PM
Clutch Slippage/Wear Goldeneagle SV Talk, Tuning & Tweaking 4 09-03-05 02:24 PM
