Old 09-09-14, 07:32 PM   #1
Yarders91
Default Leaking crank cases - curvy
Just finished touring my curvy 3000 miles around the UK for charity in under 7 days.
She never missed a beat apart from an electrical short that was easily rectified.
Anyhoo. Stepped foot into the garage today to find quiet a bit of engine oil pn the floor. Ive noticed the oil coming from a bolt on the lower of the RH bottom engine side case. Does this mean the gasket is knackered? And where can i get a new one for that side only? Ive only found complete gasket kits for sale online
Jack
Old 09-09-14, 07:47 PM   #2
Grant66
Grant66's Avatar
Default Re: Leaking crank cases - curvy
Do you mean the clutch cover? The plastic panel that has the water pump attached to it.
If yes then is quite common apparently, they warp but can be recovered.
Formerly known as Gajjii
Previous Bikes: Red Sk1 Curvy, Red MT-07.
Current Bike: Black MT-09.
Grant66 is offline   Reply With Quote
Old 09-09-14, 07:58 PM   #3
Dipper
Dipper's Avatar
I had this problem on mine, remove the clutch cover, clean up both mating surfaces and the rubber seal, refit the cover using the specified torque. Mines not leaked a drop since it was done 3 years ago.
Dipper is offline   Reply With Quote
Old 09-09-14, 08:06 PM   #4
If this doesn't work, then the cover is warped & you'll need a new one.
But that's worst case scenario
Old 09-09-14, 08:17 PM   #5
Yarders91
The leak is coming from a bolt near to the oil sight glass window. Is that the clutch cover? Im guessing to take it off i need to drain the oil to clean up the mating surfaces and re fit it?
Also where can i get the right replacement parts of that doesnt work?
Old 09-09-14, 08:26 PM   #6
http://www.robinsonsfoundry.co.uk/
Tricky to buy one 2nd hand, as that may leak too.
Old 09-09-14, 08:27 PM   #7
Grant66
Grant66's Avatar
Yes, that's the clutch cover. You can take it off without draining oil if the bikes on the side stand.
Old 09-09-14, 08:30 PM   #8
Dipper
Dipper's Avatar
Yes you will and whatever you do use the correct torque, if you over tighten it will leak again.
Old 12-09-14, 03:39 PM   #9
Yarders91
Loosened off all the hex screws and re tightened in a diagonal sequence. Still leaking. The leak is deffinately coming from a screw on the casing that the sight glass window is on. Does this mean i need a new gasket? Trying to solve this issue as quickly and cheaply as i can. But if crunch comes to crunch ill just replace it if need be.
Old 12-09-14, 03:54 PM   #10
Yarders91
Should also add that it only leaks when stood on the paddock stand. Doesnt show any evidence of leaking when its running either
sv 03 pointy crank cases jackdoyle Stuff Wanted 0 20-05-13 01:40 PM
K4 onwards crank cases Chappyr1 Stuff Wanted 0 16-02-11 12:32 PM
wanted k3 crank cases jackdoyle Stuff Wanted 0 10-12-09 04:30 PM
wanted k3 - k8 crank cases jackdoyle Stuff Wanted 0 30-10-09 04:47 PM
Pointy engine or crank cases Spikenipple Stuff Wanted 7 18-05-09 04:42 PM
