Old 31-01-15, 03:57 PM   #1
clydeflouride
Default Footrest removal? Pointy.
2010 pointy. Undone the hanger so I can see the back side. Can't get any leverage on the bolt. Rounded off the bolt that holds the master cylinder on aswell. Getting irritated now.
Wanting to bend my brake lever straight.
I see a few people have had an issue getting the peg off but couldn't see a solution.
Assuming I can get the lever off but it snaps I then need to find a way to seperate the cylinder from the rearsets to fit onto new sets.
Thanks in advance.
Old 31-01-15, 04:18 PM   #2
Default Re: how are you supposed to get the footpeg off?
you need to fix the bracket to something solid (turn upside down and affix back on frame?) to remove the large allan head bolt that holds the brake lever on as the bolt is held in with threadloc. if you have rounded the big allan bolt head you are stuffed and its drill out time. dont even attempt to use allan keys to undo it you will just round the bolt head, instead use allan sockets and a ratchet.
Old 31-01-15, 04:23 PM   #3
clydeflouride
It's a smaller one that's rounded. I'm not sure it'll twist that far round with the brake lines etc still attached. What a bloody menace. I'll try it though. I'm using sockets and a ratchet. All the gear and no idea
Old 31-01-15, 04:32 PM   #4
attach the bracket to the bike again and try using an impact driver, one good whack should see it loosen up.
Old 31-01-15, 04:39 PM   #5
clydeflouride
I'm not sure there enough clearance but I will try tomorrow. Thanks
Old 03-02-15, 02:43 PM   #6
clydeflouride
Default Re: Footrest removal? Pointy.
Definitely not enough clearance. I'm guessing I'll have to bleed the brakes, remove the footrest assembly with master cylinder still attached and have a go with it off the bike.
Rear footrest hanger bolt size? Pointy. Ravenhearts SV Talk, Tuning & Tweaking 5 20-09-14 03:06 PM
Pointy left footrest and hanger. sam-bliss Stuff Wanted 0 03-05-13 11:13 PM
right rear footrest/hanger for pointy ahmedf Stuff Wanted 5 05-03-09 05:22 PM
Exhaust mount/Rear Footrest removal Speedy SV Talk, Tuning & Tweaking 1 12-06-06 11:11 PM
Pointy/curvey footrest dimension help Flamin_Squirrel SV Talk, Tuning & Tweaking 3 26-04-05 09:09 PM
