i'm looking to put twin 5 3/4 headlights on my sv1000 shortly, but my question is about the wiring. Although my mechanical skills are spot on, my electrical skills aren't as good. What i'm looking for is a wiring harness i can buy or maunfacture that will take the power of two 55/60 watt bulbs that i can plug into the original single headlight loom without melting the existing wiring. Would be grateful for any help from you lovely people.
although Suzuki do this it's not a good idea. you really want a loom made with relays that take power form the battery but switch on hi/low with the switchgear.
if you have the angel eye (halo) as well on the lamps then you can use the side light circuit to power the halo's. i can make you up a sub loom with the OEM connector but it would mean you picking out some contacts and pushing the new ones supplied and running 2 new cables and relay to the battery. lights will be permanently on unless your existing switchgear has a switch. for me to make you up a new sub loom i would require a few pics of the OEM connector to get the wiring code from it as i dont trust the service manual. |
Is there no ends to your talents Bibs
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
I think its to look like this if i was paying attention while guzzling his homebrew
i could make up a weirdo subloom but i would require the OEM front sub loom from the bike. if there are any aftermarket indicators fitted then send them as well and i'll tidy up all the connectors.
yes there is an end to my talents.. i cant dance ![]() |
Supervox did the exact same thing on his SVthou when he had it
Ta muchly for info Viney, i know me bro would have said ta himself but hes out watching that boring game of men running around a field after a ball
thats spot on bibio. I've got some time off work coming up shortly so i'll get round the garage and look at the existing wiring setup. Thinking the halo lights might be a waste because i carn't run the side lights by themselves, so might just opt for the bog standard 5 3/4 bates instead. Thank you
#9 |
![]() ![]() Well, we will have to do something about that... Where did I leave my tap shoes? ![]() |
#10 |
You could always buy a bibio gizmo and mod that to switch the lights via the battery
would save some work too |
650 K3 Naked Twin Exhaust Conversion | SV-net | SV Talk, Tuning & Tweaking | 10 | 09-04-08 04:54 PM |
SV1000 Twin Exhaust on 650? | SV-net | SV Talk, Tuning & Tweaking | 8 | 25-11-07 06:45 PM |
twin exhaust conversion | jon8oy | Stuff Wanted | 10 | 06-06-07 06:19 AM |
06 Naked to S conversion | 007SV650 | SV Talk, Tuning & Tweaking | 7 | 21-04-07 12:10 AM |
Better light with HID Conversion Kit? | zunkus | SV Talk, Tuning & Tweaking | 13 | 18-08-05 06:10 PM |
