Whoever had the idea to put Allan head screws in the back of a hot exhaust on a motorbike want shooting in the face!
Three of four seized on each silencer.... How is best to remove these? I don't mind replacing them but been Allan bolts the key just wants to twist out or even round off just can't get the purchase I need! Any ideas on how to remove? Thanks in advance ![]() |
Knob faced knobster
Are they cap or button head bolts?
2001 SV650 in shimmerin green, Not broken anymore |
Daft button head bolts! Couldn't have made it more awkward
Knob faced knobster
What a stupid idea to use Allen bolts let alone button head ones!
I think if they're tight enough that they're going to round out you may have trouble with them shearing off you can get something on them. I was going to suggest irwin bolt extractors if they were cap head. You still be able to get the bolt extractors on a button head but the socket won't have much to bite into, I've used them on a tokico caliper that the Allen bolts were rounded out
2001 SV650 in shimmerin green, Not broken anymore Last edited by dirtydog; 15-03-15 at 12:13 PM. |
all the exhaust studs on pointys are allen head.
bit late now but if you are taking the exhaust off you loosen the two clamps, dont touch the rear exhaust header ones and fully remove the front header ones then remove the front downpipe and take the rest of the pipework off leaving the rear downpipe in place. |
Cheers bibio.... I just I need the rear silencers off ready for the mot next month (lost a baffle last mot when I went for a blast forgetting that I only finger tightened them for the test... DOH)
Access is a pain as well because of the hangers but I can soon remove them. Bit idiotic using button Allen heads on a exhaust if you ask me..... Morons! Never mind tho ey! If I drill the top off it's not going to leave me much bolt to grab with pliers either.... Hmmm might be easier to just give it to a garage and make it their problem |
#7 | ||
Someone one here posted up removing stuck bolts using a similar method to this. Depends on your access
Thanks maviczap I'll have a go with the punch this next week see what I can do
#9 |
These bolts are not bad quality and should have moved quite easily with a good quality long series key, especially if you give them a sharp hefty tap on the head first. Mine came out easily when I fitted after market cans at about 10K and came out easily again yesterday ( after 7 years ) when I removed most of the system to replace the rear collector gasket. You should be able to cut a slot in at least 3 each side to attack with a large driver. The inaccessible one on each with prove tricky and may need drilling. Use graphite grease on reassembly.
Alan
"I can see Paradise by the SV's light" TCX Competizione S boots saved my foot ![]() |
#10 |
Cheers Alan! I suspect with a name like yours you had something to do with the invention of these and are therefore a ambassador for Allen bolts across the globe.... Shifty....
exhaust removal | Alexander94 | SV Talk, Tuning & Tweaking | 33 | 17-09-15 04:27 PM |
Exhaust removal question. | Redman2722 | SV Talk, Tuning & Tweaking | 8 | 08-02-13 09:25 PM |
exhaust removal | elkieboy | SV Talk, Tuning & Tweaking | 5 | 19-03-10 03:58 PM |
Exhaust dent removal | natcar | Bikes - Talk & Issues | 2 | 12-08-08 05:44 PM |
Exhaust removal issue | chakraist | SV Talk, Tuning & Tweaking | 13 | 07-08-08 09:19 PM |
