Old 30-05-15, 10:53 AM   #1
Aldoo
Default Coolant
Hi, just a quick question - hopefully an easy answer and not a can of worms type thing!
Changed the coolant on my curvy and filled to the top of the radiator - but roughly how much do you then put in the reservoir at the top?
Due to it either being old and dirty or having the wrong coolant in the past I can't see the level at all through the 'clear' bit
Old 30-05-15, 08:55 PM   #2
prokartman
prokartman's Avatar
Default Re: Coolant
The " clear " bit is not very clear at all . I found that if you hold a bright torch from against the engine pointing back towards the resevoir with a bit of manoevering to get it in the right position it just enables you to see the coolant level , not ideal but it worked for me .
prokartman is offline   Reply With Quote
Old 30-05-15, 09:16 PM   #3
Default Re: Coolant
ermmm stick your finger or a rule in as a gauge. its only an expansion bottle if there is too much then it will spurt out till it gets to the right level, as long as there is some liquid in there all is well.
Old 30-05-15, 09:21 PM   #4
Aldoo
Default Re: Coolant
Ill try the light idea next time i have the tank up
It seemed to brim as soon as I put some in though!
I just pulled a bit out with a syringe and thought it'd do
I guess you're right bibio - its only coolant, not oil or anything lol
Cheers guys
Which coolant for SV 650 SK8? F4LL3N SV Talk, Tuning & Tweaking 2 10-07-12 07:09 AM
Is this coolant ok? Scythe92 Bikes - Talk & Issues 2 17-03-12 10:54 PM
Oil in coolant ?! fatneck Bikes - Talk & Issues 16 26-02-08 09:14 PM
Coolant help therealvw SV Talk, Tuning & Tweaking 3 07-08-07 08:02 PM
Sorry -coolant again tomjones2 SV Talk, Tuning & Tweaking 6 17-06-06 09:47 AM
