Racing and Paddock Chat The latest news, talk, and gossip from the world of bike racing, you can also discuss track days here too.
Old 17-08-15, 10:58 AM   #1
craigmcgleish
Default Rear disc and pads also rear pedal clicking
Hi all
Looking to fitting new pads and disc (rear) could anyone recomend decent priced cheers
Also rear brake pedal when pressed down goes hard then clicks and is then proceeds to push down more does anyone have any idea on what this could be it feels although the spring may be catching on something then clicks out?
Old 17-08-15, 01:39 PM   #2
ophic
ophic's Avatar
Default Re: Rear disc and pads also rear pedal clicking
The spring is only there to return the lever to its original position - I wouldn't expect it to be able to make the lever go hard, even if it caught on something - you'd just break the spring.
Silver SV650SK3, Fuel exhaust
Old 17-08-15, 01:43 PM   #3
craigmcgleish
Sorry when i mean hard im meaning the brake is on and is braking then when it clicks the pedal seems to go down that little futher the whole foot pedal its self can rotate slightly is this normally tight without movement?
Thanks
Old 17-08-15, 01:46 PM   #4
ophic
ophic's Avatar
Normally only the brake lever moves.
Old 17-08-15, 04:07 PM   #5
craigmcgleish
ok thanks i will have a look see if i can get in to tighten this and see if there is any change
Old 17-08-15, 04:43 PM   #6
Alexander94
When I replaced my rear brake pedal the rod that goes into the master cylinder wasn't straight, what you're describing sounds similar to what was happening in that situation.
As for discs, I've just ordered an "Arashi" rear disc g ok China, they're meant to be good I'm just waiting for it to turn up to see, it was £25 delivered
Old 11-09-15, 12:37 PM   #7
ste12100
I recently bought some Arashi brakes , they seem fine on my bike about 1600 miles on them so far.
Curvy wheels, Front disc, Rear disc yorkie_chris For Sale - SV's and SV related items 6 18-07-12 11:57 AM
99-02 rear brake pedal Marcus Stuff Wanted 17 14-04-09 07:27 PM
Rear Brake Pedal 01 sv650s Stuff Wanted 1 29-03-07 10:11 PM
Rear break pedal Steve226 Stuff Wanted 3 15-11-06 11:19 AM
rear brake pads/disc rubbing will SV Talk, Tuning & Tweaking 4 02-03-06 10:19 AM
