Old 22-11-15, 03:52 PM   #1
JonSV
Default Static Wheel Balancers
I've now changed my first tyre so might as well finish the job properly. I can see 3 main options, anyone that has used any of them got any advice on which to go for?
Cheap option
Warrier
Middle option
Tech 7
Expensive option
Abba
Old 22-11-15, 04:35 PM   #2
robertw95
Default Re: Static Wheel Balancers
I have one similar to the 2nd option, done the job perfectly for me so far.
robertw95 is offline   Reply With Quote
Old 22-11-15, 06:31 PM   #3
Red Herring
Red Herring's Avatar
I've got the Abba set up and it's been brilliant for the last 20 years...... If I divide the initial cost by the number of wheels I've balanced it was really cheap......
Be careful of the first option, if you only have one paddock stand what do you stand the bike on whilst you balance the wheel....
ps" don't forget to get a bead breaker as well......
Old 22-11-15, 07:04 PM   #4
curlylee
ive got option 1 easy to use and no problems, only difference is the stands between all of them
curlylee is offline   Reply With Quote
Old 22-11-15, 08:22 PM   #5
Fen Tiger
I have the Sealey version. Works well. OK for occasional use anyway.
Fen Tiger is offline   Reply With Quote
Old 23-11-15, 07:09 AM   #6
JonSV
Sounds like any of them would be OK then. Might go for the cheap option plus a spare paddock stand, I've only got an Abba stand at the moment so it will come in handy if I decide to get tyre warmers one day.
Old 23-11-15, 07:11 AM   #7
JonSV
That would be lazy when tyre levers work
Old 23-11-15, 08:12 AM   #8
Red Herring
I guess it depends on how much you love your rims.....
Old 23-11-15, 06:46 PM   #9
Toooldtodie
Toooldtodie's Avatar
If you already got an Abba stand then you can get the Superbike accessory addition to get all wheels off the ground. Super stable.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 24-11-15, 10:58 AM   #10
NTECUK
NTECUK's Avatar
Big water butt spirit level job's a good un
Group Buy - Carb/TB permanent extension Tails for balancers Bibio SV Talk, Tuning & Tweaking 116 14-10-15 05:11 PM
carb balancers loonytoon Stuff Wanted 18 20-02-11 11:56 PM
Static wheel balancer? ricky Bikes - Talk & Issues 7 01-02-10 08:35 AM
Carb balancers and air boxes drag SV Talk, Tuning & Tweaking 32 16-07-09 08:44 AM
Carb balancers I could borrow? sam anon SV Talk, Tuning & Tweaking 3 21-11-08 06:49 AM
