Old 15-12-15, 10:51 AM   #1
shiftin_gear98
shiftin_gear98's Avatar
Default Leak in car
So ****ed off...
That is all.
Currently driving a Corsa....
Old 15-12-15, 12:37 PM   #2
NTECUK
NTECUK's Avatar
Default Re: Leak in car
Should have gone before you left =:0
Old 15-12-15, 01:05 PM   #3
Corny Gizmo
Take it out, its only a vegetable!
Old 16-12-15, 06:43 AM   #4
Should have wound the windows up before using the carwash
Sent from my E2303 using Tapatalk
Old 16-12-15, 10:28 AM   #5
NTECUK
NTECUK's Avatar
I knew someone who got too Wales in a car
Old 16-12-15, 03:51 PM   #6
shiftin_gear98
Old 17-12-15, 12:34 PM   #7
Ratty
Ratty's Avatar
Daughter's Clio is like a swimming pool at the moment. Tons of stuff about dodgy sunroof seals and drains on Youtube. Looks like I'll be resealing it over the holidays. Tape poly over the sunroof if it has one and see if it dries out. Use towels, then wood pellet cat litter to dry is out.
Ratty
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Old 17-12-15, 12:55 PM   #8
My old Cavalier was getting soaking wet carpets, as the drain for the heater air box was blocked up, so it filled up with water and drained into the outlets for the hot air, soaking the carpets.
Old 17-12-15, 02:58 PM   #9
There's a hole in my motor, dear org... dear org...
Old 17-12-15, 03:01 PM   #10
timwilky
timwilky's Avatar
Ratty
Lynne's clio leaked like a sieve through the paper sun roof seal. It was a bit of a faff to remove it as you have to pull the head lining out the way to get at the dozen bolts. But probably an hours work to remove, apply a ring of silicon and refit. 2 years later, I was in the car yesterday. (Hasn't moved for over a year whilst we wait for daughter no2 to get round to passing her test so exposed to plenty of wet lately) and it is still bone dry.
Tip no 2, whilst you have to roof out. Blow an air line down the drain tubes to clear any potential blockage.
Not Grumpy, opinionated.
Oil leak 02 Sv650s Black Bikes - Talk & Issues 2 08-05-10 09:58 AM
Oil leak maultin SV Talk, Tuning & Tweaking 14 13-02-08 05:56 PM
Help oil leak puter killer SV Talk, Tuning & Tweaking 8 08-01-08 12:29 PM
Help - Oil Leak. sprocket SV Talk, Tuning & Tweaking 9 21-06-07 08:05 PM
Not oil leak - Petrol leak - double "Bugger"...! Potts SV Talk, Tuning & Tweaking 1 17-10-04 08:16 PM
