Old 01-03-16, 07:15 AM   #1
mancboy
Default another brake seal question!!! (sorry!)
Hi again,
after sorting out my leaky clutch issue it seems one of my calipers were binding on the front. regreased the float but this didnt help or only a bit so I had to for the firs time strip the caliper. First thing I noticed was there was no dust sheild so not sure if its been done before by dodgy bobs back street garage! but suprised it hasnt gone before.
next thing I notcied is the seal was perfectly round? I thought they had to go in a certain way and one edge had a wider rim than the bottom part?
Ive sent off for the new ones but what do I do if the new ones look the same? again im thinking dodgy bob just stuck any seal he had on the shelf so hopefully the new ones will per as per spec.
Old 01-03-16, 12:40 PM   #2
timwilky
timwilky's Avatar
Default Re: another brake seal question!!! (sorry!)
Although manuals suggest he seals have a wedge profile
This is not the case.
Refresh your seals. Use Red rubber grease and give the seal recesses a good clean first
Not Grumpy, opinionated.
Old 01-03-16, 01:25 PM   #3
mancboy
thanks mate at least i know its not my eyes lol
Old 02-03-16, 06:52 PM   #4
mancboy
Can I just double check, red rubber grease goes on inside of caliper chambers, outside of pistons, seals, dust seal and float is that right. I got some silicone grease to after reading something but cant remember what for lol. I used to use copper grease on bake of brake pads but remember someone saying use something else??
Old 04-03-16, 05:50 PM   #5
Toooldtodie
Toooldtodie's Avatar
Yes. That was Bibio. He's forgotten more about SVs than I know, so he's a bit like Moses and commandments when it comes to bikes.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 05-03-16, 02:37 PM   #6
mancboy
hahaha cool ok.
well its all been done and I re -checked it afterwards as the disc was still getting a little warmer than the other side. I need to do a good run really. Its off for the mot on wednesday so that may show something. Im happy the pistons and float are both working fine. Im wondering maybe the disc is a little warped but a tool is like £60!
Old 05-03-16, 03:21 PM   #7
Toooldtodie
Could it just be the disc bobbins needs a good clean and freeing up a bit?
Old 06-03-16, 05:11 PM   #8
mancboy
am i being thick lol, what are the disc bobbins? im going out for another spin in a second to see if its any better after a re grease of the caliper float. the pistons pump out nice and even and the float moves well so its a bit of a weird one. will give the disc a clean before going out. ill update in a bit hopefully.
Old 06-03-16, 08:19 PM   #9
mancboy
Well went for a spin. Didnt use the brakes for a mile straight as I thought if they are binding the disc will be hot. Luckily they wasn't. When I did use them one disc was stone cold the other slightly warm so maybe a warped disc slightly or could it be to do with me not changing seals on both calipers? Anyways it seems OK nothing to panic about. I'll see if the garage can test for a warped disc on Wednesday
Old 07-03-16, 07:12 PM   #10
Toooldtodie
Glad it's all working out.
Answer to your question, check this vid out.
https://www.youtube.com/watch?v=1qoPqN2GBdw
'S' front brake reservoir cap & seal AlexAdams Stuff Wanted 1 18-11-15 01:49 PM
Missing brake seal? sputnik Bikes - Talk & Issues 1 26-01-15 12:43 AM
Fork seal question mickhew SV Talk, Tuning & Tweaking 9 12-01-11 05:48 AM
Fork seal question. Sideshow#36 SV Talk, Tuning & Tweaking 1 22-02-08 06:12 PM
Brake seal suppliers chazzyb SV Talk, Tuning & Tweaking 7 09-03-07 10:44 AM
