Old 06-03-16, 05:15 PM   #1
Stuart42
Default Oil Level Rises When Turning Engine
Hi all
I've just refreshed my piston rings and having put the engine back together the oil level rises when I turn the engine over.
Naturally the oil light doesn't go out either, so what have I done wrong?
Stuart
Stuart42 is offline   Reply With Quote
Old 06-03-16, 10:02 PM   #2
DJ123
DJ123's Avatar
Default Re: Oil Level Rises When Turning Engine
Originally Posted by Stuart42 View Post
Hi all
Stuart
1-How do you mean rises?
2-The oil light is for pressure. IIRC it will only go off once the engine is running and pressure is being registered
BMW F800ST
Old 07-03-16, 09:03 AM   #3
Stuart42
Hi
When you look in the sight glass the level raises as the engine is turned over.
To my mind, and from what I can remember it should drop as the oil is pumped round?
In the past when I have cranked engines over, even though the engine is not running the oil light will go out when the pressure is reached.
I didn't have the plugs in as I wanted to make sure oil was circulating around the engine as it had just been rebuilt.
Stuart
Old 07-03-16, 12:36 PM   #4
Odd!
Have you put the oil pump in backwards somehow? Can't remember if this is actually possible but if it was just blowing bubbles in the sump it may give this effect.
And yes, when all is well, the oil light will go out when cranking.
Old 07-03-16, 01:06 PM   #5
Stuart42
Hi all
Just spoke with Slick Bas who did the work on the engine, and turns out it was an air lock in the oil filter.
Nice simple, easy, cheap fix, luckily.
Stuart
Old 07-03-16, 01:45 PM   #6
I've had to take the oil pump out and pour oil into the galleries before to get one to prime.
Odd considering that sort pump should self prime, but oh well...
Old 13-03-16, 09:40 PM   #7
Jamesreabrookes
So fixed with just oil and filter change?
What caused the airlock do you know
Old 13-03-16, 10:02 PM   #8
Stuart42
Problem occurred as there was oil in the filter, was just changing the oil, and the air lock was between new oil in sump and old oil in filter.
In future I will keep an eye on the level when I first start it after an oil change
Sturt
Oil level and engine noise nikon70 Bikes - Talk & Issues 25 18-06-14 09:13 AM
Engine problems after low oil level. en51nm SV Talk, Tuning & Tweaking 37 04-05-12 07:10 PM
low engine oil level - possible damage? Weetabix SV Talk, Tuning & Tweaking 7 28-07-11 05:45 AM
Engine turning over but not firing ophic SV Talk, Tuning & Tweaking 6 24-03-10 01:54 PM
checking oil level, engine running or not ricky SV Talk, Tuning & Tweaking 7 23-05-08 06:17 PM
