Old 11-03-16, 05:33 AM   #1
kmsv2001
Default Severed wires
Someone recently tried to steal my bike and in the process severed a bundle of wires. I'm wondering if I should try to solder the wires or if I were to replace the wires, do I need to rewire everything or just replace the whole bundle? The shop I called gave me a rough estimate of $1100. The wires are in the front and connect to the starter. I've attached a photo. I'd appreciate any advice. Thank you!
Old 11-03-16, 09:36 AM   #2
timwilky
timwilky's Avatar
Default Re: Severed wires
Scumbags, need their pliers applying to their nether regions.
Personally, I would try to solder/heatshrink the cuts. Depending how much loose cable is available, you may have to splice in short sections to give you space to make the joints.
Not Grumpy, opinionated.
Old 11-03-16, 12:03 PM   #3
moblies
As above I would get some similar gauge wire and solder in a short section if not enough room then heatshrink each one and then wrap back up in insulation tape. I would think replacing the loom would be a pig of a job unless the bike is stripped down.
Hope you get it sorted
Old 11-03-16, 05:46 PM   #4
Those wires are not the main loom, they go from a multi plug on the loom to the left switchgear. The light blue gives that away - light blue is Suzuki for indicator. The reason the bike won't go is that the clutch switch wires - black/yellow - are severed.
Repairing wires in that area is tricky, they need to have as much flexibility as possible or they will soon be damaged.
Either cut sections out and replace such that the joins are in areas that don't need to flex, or replace the switchgear - early switchgear on eBay is £20 or so.
Old 12-03-16, 10:54 PM   #5
kmsv2001
Thanks for the input, guys. I'm going to attempt to add wire and solder tomorrow. I'll let you know how it goes.
wires yamrdtez Bikes - Talk & Issues 5 27-11-15 04:50 PM
Pointy reg/rec wires getting hot Andydrz SV Talk, Tuning & Tweaking 9 08-08-14 10:08 PM
Do I need these wires? Curvy. bubbleo SV Talk, Tuning & Tweaking 11 13-03-14 05:06 AM
Extending Wires In A HID Kit? CAhmroiss Bikes - Talk & Issues 0 05-01-14 09:20 PM
2nd/3rd wires andy owen SV Talk, Tuning & Tweaking 1 29-01-06 05:08 PM
