Old 22-07-16, 12:42 PM   #1
baldricc
Default sv1000sk3 blowing main fuse
When out riding and bike is at 5500 rpm for any amount of time rev counter sticks at 5500 and main fuse blows put new fuse in an rev counter zeros and all electrics back to normal. This has happened couple of times any help gratefully appreciated.
baldricc is offline   Reply With Quote
Old 23-07-16, 08:44 AM   #2
Default Re: sv1000sk3 blowing main fuse
If it's only ever the main fuse that pops, check all the other fuses are the correct ones. If they are, then the fault is located in one of a few quite specific areas:
Solenoid
Black-red wire from the solenoid to;
1 regulator (there's two, they're doubled)
2 fuse labeled 'fuel'
3 ignition switch
Ignition switch itself
Orange wire from ignition switch to;
1 left switchgear
2 fuse board
If the fault were further down the system, the relevant sub circuit fuse would pop, the above mentioned areas are the only ones that are protected solely by the main fuse. This of course assumes that no-one has used a screw instead of the correct fuse in one of the sub circuits. All bets are off then.
The wiring in the main loom is well protected, so the fault likely lies in one of the branches that go to the above mentioned areas, check them carefully for damage before looking deeper.
blowing main fuse(30amp) svrush SV Talk, Tuning & Tweaking 10 12-04-16 05:07 PM
Main Fuse A' Blowing squirrel_hunter SV Talk, Tuning & Tweaking 12 16-08-11 08:44 PM
30 amp main fuse blowing - effects? kevo115 SV Talk, Tuning & Tweaking 14 14-02-11 09:51 AM
fuse keeps blowing bobm SV Talk, Tuning & Tweaking 5 23-10-08 07:57 AM
Main fuse keeps blowing JMCHITTOCK SV Talk, Tuning & Tweaking 7 09-09-05 11:17 AM
