Can you confirm if this means my stator is shot, or if i'm an idiot who can't do this properly ?
i included the service manual page so can see for yourself. stator.jpgIMG_5790.jpgIMG_5791.jpgIMG_5792.jpg |
I couldnt put all the pictures, but i tested the resistance between the 2 stator wires that are together, and between the 3 of them that are together (all combination and including a ground test through the frame of the bike which didn't show any current).
However number said .8 throughout the 3 wires combination tests, and that 193 number between the 2 wires. seems like it should be max .55 for the 3 wires and online I foundout that testing for continuity between the 2 wires should probably give a umber close to zero. Is that right? |
yes youre right the readings should be a max of 0.55 ohmns but I would expect a failed stator to give unbalanced readings either really high or low not the same on all three phases. Normally only one of the three coils fails and goes open circuit or shorts out with, frequently in the latter case, a low resistance to the frame.
I recommend carrying on with the other tests.... Last edited by glang; 08-09-16 at 07:03 AM. |
Give the guides in my sig a read through, they are very easy to follow and must be if an idiot like me can follow them
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
i think your measuring the wrong connector. remove the 3 yellow wire plug that goes into the 3 white wires from the reg/rec and measure the ohm reading there.
just to remove some confusion: these picture are for the stator test, not the regulator test. I actually have a weird reading with the regulator test too, but didn't want to confuse the issue of this stator test reading. (plus I couldnt put up any more pictures).
Glang I am going to do just that: waiting on my new battery to test the stator while going up to 5000 as the service manual says (if I manage to turn the bike on!).I did test the shorts with the frame and that was normal (not showing any thing) For the regulator (another test not pictured here) what what weird in my testing is that i get numbers in the 530s something (yes on the diode test, the one with the arrow) but also consistent across all 3, and nothing the other way (when I switch red and black probes to do the test again that way). I think maybe I shot both stator and regulator. the battery was fried and the headlight fried too when the bike stopped working. |
#7 | |
look at the diagram it clearly states Y for ermm Yellow |
#8 | |
(yes I made sure to be on the diode, the arrow, just like the guy in the video) |
#9 |
I did that (last picture and other pictures I couldnt post because it maxed out) and the reading came out at 0.8 on all 3 yellow wire combination. which is my question: does that mean it's shot?
#10 | |
Few pictures from Wigan test day 10th May | mister c | Photos | 1 | 11-05-13 08:10 PM |
Crash.NET - PICTURES: Mugello MotoGP Test | NewsBot | News | 0 | 16-07-12 10:30 AM |
Crash.NET - PICTURES: Sepang MotoGP test | NewsBot | News | 0 | 04-02-10 06:50 AM |
Crash.NET - PICTURES: Rossi's Ferrari F1 test | NewsBot | News | 0 | 20-11-08 08:50 PM |
Crash.NET - PICTURES: Valencia MotoGP test. | NewsBot | News | 0 | 27-10-08 11:20 AM |
