Old 26-10-16, 02:57 PM   #1
johnnyrod
johnnyrod's Avatar
Default Kitchen plinth heater questions
One for the plumbers! We are having a new kitchen after Christmas and are going to put in a plinth heater. We had one at our last place and were pretty happy. It's going to be a dual one (electric/hydronic), but I have a few OMO questions. Anything to choose from between Smiths and Myson? Given a kitchen can get warm on its own, should we add a room stat for it? I think this just cuts off the fan when it gets too warm, as I understand it. In that case, does that not just send hot water back to the boiler return (as the heat isn't being given up) and upset the temperature difference? They are about 3500BTU-ish, we have a pretty big house and a 30kW/100,000BTU condensing boiler. I don't know if I'm worrying about nothing; temperature differences are a bit of a black art/ideal state. I can't remember the kitchen in the last house getting hot when we were cooking and the heating was also on.
Thanks a lot
Old 28-10-16, 01:47 PM   #2
embee
embee's Avatar
Default Re: Kitchen plinth heater questions
Can't give any views on the makes, but FWIW I have serviced one for a friend. That's hot water only with a fan, there's a separate room stat for it which switches the fan. That works fine.
The issues they have had is the small bore pipes blocking, even though the overall system is kept clean. When having it fitted make sure they fit some convenient full bore isolator valves (preferably with handles) and make it easy to get out from under the units so you can flush it out. Think about how long the flexibles are etc. Nothing worse than not having enough free movement to wangle it in/out or having to remove stuff in order to get to the isolator/service valves.
Carb heater question sprocket SV Talk, Tuning & Tweaking 14 13-06-18 01:58 PM
Is this patio heater any good? Ed Idle Banter 9 14-03-11 08:35 AM
Recommend Me... A Garage Heater squirrel_hunter Idle Banter 27 21-11-09 09:48 PM
Carb heater Jase22 Stuff Wanted 0 01-11-06 06:05 PM
Underbike heater ? Gforceuk Bikes - Talk & Issues 15 23-11-04 08:56 AM
