Old 01-12-16, 09:47 PM   #1
Adam Ef
Adam Ef's Avatar
Default Heavy bar end weights?
Can anyone recommend any heavy bar end weights? No none seems to list the weights in online stores. Looking to help reduce vibration on the bars of a 250 single at hi revs. So guessing heavier the better. To fit 22mm bars.
Old 02-12-16, 12:36 AM   #2
TamSV
TamSV's Avatar
Default Re: Heavy bar end weights?
Oberon large stainless bar ends have a decent heft.
They need to be the stainless steel mind. The aluminium bar ends weigh nowt.
Old 02-12-16, 01:03 AM   #3
rictus01
rictus01's Avatar
you may want to try getting a pair of early GSXF (600 &750 are the same), they are two piece a lead inner and a steel cover, almost twice the weight of standard SV ones.
Old 02-12-16, 09:51 AM   #4
SV650rules
To test if it will work with heavier weights get some plumbers solder (its about 5mm diameter, most hardware shops like B&Q sell it) and wrap it either round existing weights (if they have a protruding section ) or as near to end of bars as you can get, you can easily add and remove weight in this way. If the extra weight does not damp vibration you needn't waste money getting heavier weights - and need to look at something else as a cure for vibration.
2016 SV650 AL7
Old 02-12-16, 10:37 AM   #5
tom_e
I've got a set of the lighter ones on mine and they make a big difference.
http://www.oberon-performance.co.uk/...d_Weights.html
tom_e is offline   Reply With Quote
Old 02-12-16, 01:17 PM   #6
Blapper
Blapper's Avatar
I noticed that my Renthal ultra-low bars vibrate a lot less than my standards even though they are ali. Summat to do with the fact they are double skinned or double thick walled.
Or you could pour lead shot into your bars? Available from gunshops in bottles.
Old 02-12-16, 03:40 PM   #7
Although you're looking for a 250 single, my Sv has R&G bar ends, as I have Gilles Vario Bars, which don't use the standard SV bar ends.
I don't notice any vibration through the bars & these are a lot lighter than standard SV bar ends. I also have Rethal grips.
Old 02-12-16, 04:02 PM   #8
carelesschucca
carelesschucca's Avatar
I have a friend the claims you can pour sand into your bars and that would work as a dampener.
But I'm pretty sure he worked in a chip shop and claimed he was Elvis.
Old 02-12-16, 10:23 PM   #9
heavy bar ends can make matters worse. ask yourself 'what is vibration' then think about a badly designed bridge.
Old 09-12-16, 06:44 PM   #10
F2 man
Heavy oberon work a treat
Bar end weights andyb For Sale - SV's and SV related items 0 20-06-10 05:40 PM
Bar End Weights hkhksh Stuff Wanted 0 01-02-10 08:54 PM
Bar end Weights metalmonkey SV Talk, Tuning & Tweaking 23 08-11-09 09:30 AM
Bar end weights Banus SV Talk, Tuning & Tweaking 1 15-07-07 09:51 PM
Bar end weights - What do they do? Mark_h SV Talk, Tuning & Tweaking 3 31-12-05 08:56 PM
