Always meant to sort this out, my pointy lower fairings but together in the belly region with 4 holes that are cable tied in pairs. Can't believe this is standard, should there be a plate with 4 plastic pop rivets?
Black 2010 SV650S Fully faired White 2011 YZF R125 sold |
If it is anything like the curvy, there are clips that push over one side then screws go through the other side into the clips. Go to your local dealer for them - they shouldn't be toooo expensive
Thanks Blapper
Junior Member
Hi , On my 2004 K3 there is a small black plastic sort of panel/hinge at the bottom with four holes. On my bike there are currently three plastic rivets attaching the fairing to this so am looking to get some on ebay , I think this is the link ..
http://www.ebay.co.uk/itm/20x-Suzuki...-/371405317080 Cheers Steve |
Ah, so the pointy is different then.
Junior Member
Yes I guess pointy's are different from your description. The holes on my fairing are 6mm dia ( the rivets come in 6 or 8 mm diameter packs ) , there are multiple suppliers on ebay. The black plastic plate/hinge thing is approx 55mm square. Cheers Steve
Pointy lower fairing fixings. | Wayno | Stuff Wanted | 17 | 05-04-14 05:05 PM |
YC2 belly pan or lower fairing wanted | joe_f59 | Stuff Wanted | 3 | 13-09-11 08:09 PM |
Pointy belly pan/lower fairing fitting kit - dimensions please | .aj. | Bikes - Talk & Issues | 0 | 02-09-10 07:44 AM |
Lower Fairings / Belly Fairing | cloudsurferuk | SV Talk, Tuning & Tweaking | 4 | 23-07-10 05:03 PM |
lower fairing fixings | gralln9 | Stuff Wanted | 0 | 12-08-08 03:39 AM |
