Old 31-10-17, 10:39 AM   #1
TheAdmiral
Default Final problems before she's on the road
Hi guys, i bought an sv650k3s back in February as a project for over the summer, it ended up being a ball ache because problems just kept arising, but she's finally almost there.
The issues i'm facing and need advice on how to move forward are:
- The bike seems to sometimes only run on one cylinder whilst sat idling in my garage
- The killswitch doesnt work (Doesn't really bother me)
- Side stand cutout switch doesn't work (Already replaced it to no effect)
Any input is greatly appreciated
Dean
Old 31-10-17, 01:19 PM   #2
Default Re: Final problems before she's on the road
good advice from Seeker, also check the fuse. kill switch not working is an MOT failure.
Old 31-10-17, 08:02 PM   #3
punyXpress
punyXpress's Avatar
Is it the front pot that dies?
Spit on the pipe to find out.
If so, the plug recess drain is probably full of water.
Now: Street Triple R
Old 06-11-17, 02:26 PM   #4
TheAdmiral
Thanks everyone, the cylinder issue was just a fouled spark plug which had accumulate some gunk and wasn't sparking properly no the front cylinder (put new plugs into both cylinders just in case).
The killswitch and side stand cut outs are the only issues with it now, i'll try find the wiring diagram online and trace and test the wires.
Thanks guys!
Dean
Old 07-11-17, 11:00 AM   #5
TheAdmiral
Is there any chance it could be a blown fuse? both wires go straight to the fusebox.
Shown here: http://cycles.evanfell.com/wp-conten...ng-Diagram.jpg
Old 07-11-17, 02:31 PM   #6
TheAdmiral
Thanks, the side stand switch isn't the issue mechanically (Unless i'm really unlucky) i've already tried a different one which i bought on ebay and just plugged straight in to the original green plug under the tank to no success.
The right switchgear is a little bit bust up with a crack along the side but all other buttons are working to i've no idea why that one switch wouldn't work.
I bought a new RH switch gear but it doesn't have the throttle cable casing so i've just stuck with the original one.
Thanks though
Will check the plug after uni tonight.
As well as the fusebox and RH switch gear to check for broken wires inside it.
Dean
Old 07-11-17, 02:59 PM   #7
is your bike a sport (faired) or naked style SV?
with it being a K3 is it a very late curvy or an early pointy shaped SV?
Old 12-11-17, 10:45 AM   #8
TheAdmiral
It's an early pointy, the first pointy model i believe
Road Tyre Pressures and tyre problems G Bikes - Talk & Issues 14 05-06-08 03:29 PM
Problems with road horn slydog SV Talk, Tuning & Tweaking 5 18-04-08 01:31 PM
Jensen Button, part 7: "The final, final showdown" Anonymous Idle Banter 34 21-07-06 03:23 AM
Quill Road Legal Can (Problems) TheMickster Exhausts 8 09-11-05 08:33 PM
SKID WARNING - Junct Tennison Road/Davidson Road in Selhurst 21QUEST Bikes - Talk & Issues 0 19-08-05 09:27 AM
