Old 09-11-17, 12:54 PM   #1
Jayneflakes
Jayneflakes's Avatar
Default R & G heated grips for K3
Hi folks, just after a quick opinion. I am looking for heated grips now that the arthritis is biting into my hand bones and while perusing the internet I found a set by R & G claiming to be specifically made for the K3. What I can see looks fairly generic and it is just a way for M & P to get extra sales.
Anyway, have any of you fitted them at all? How well do they work and are they worth the investment?
The advice from my GP is that I need to keep my hands warm at all times and thus if these are any good, they will be going on the Christmas list.
This is the evil Bay link so do please let me know if you have a helpful opinion. Sadly I miss the old days of having a Keith D answer!
Jayne you're a Pussy Magnet
Old 09-11-17, 01:18 PM   #2
Default Re: R & G heated grips for K3
I found with heated grips that I was holding on to the bars tighter to feel the warmth, so my hands got tired very quick. They also don't warm the exposed side of your hand or your finger tips. I think you'd be much better with heated inner gloves
Old 09-11-17, 01:38 PM   #3
Jayneflakes
Thank you for your comment, that is something to think about.
Old 09-11-17, 01:46 PM   #4
Stilo
Stilo's Avatar
And bolt on hand shields, you would be surprised how much wind they keep off
He was a hairy handed Gent who ran amok in Kent Awhooo
Stilo is offline   Reply With Quote
Old 09-11-17, 01:49 PM   #5
i sort of agree but it really depends on how cold the outside temps are and the type of gloves you use. thin gloves dont keep the heat in and makes things cool down too quick so to be effective you need to use winter gloves.
heated gloves are the answer and the only thing i found with heated gloves is the cable's are nippy. i ended stitching the cables into a top. you have to get used to remembering to connect/disconnect every time you get on/off the bike but you soon get used to it. depending on how far you go then battery powered ones might be a better idea.
ooohhh and the grips are not bike dependant, its just an advert for those that cant work things out.
Old 09-11-17, 02:11 PM   #6
Jayneflakes
Thank you chaps, informative as always.
This is something that I have considered, but with the modifications I have already done, room is tight up there already. This is because I have a six inch bar lift over standard.
This is a bit of a worry, I am currently struggling with thicker winter gloves because it has increased my pain levels in my knackered fingers. I was hoping that I would be able to use thinner gloves. If only I had listened at school when they said that finger bingo was bad for us!
Given that I ride very little in winter due to pain, battery powered gloves may be perfect for me. I could also use them for other occasions (keep it clean folks! ) such as winter walks to the shops. Do you have a recommendation for a good brand to look out for?
As I thought, thank you.
Old 09-11-17, 02:29 PM   #7
something else i will add. gloves and their sizing, too tight a glove will cause pins'n'needles as it stops the blood circulation to the tips of your fingers. if there is any pressure on the tips of your fingers then the gloves are wrong. gloves are like boots they must be tried on and fit correctly.
Old 09-11-17, 03:43 PM   #8
ophic
ophic's Avatar
I can categorically state, from my old 55 mile each way all weather motorway commute, that hand guards and heated grips are not enough for seriously cold weather. They're quite convenient for tootling around town, mind.
Silver SV650SK3, Fuel exhaust
Old 09-11-17, 03:54 PM   #9
timwilky
timwilky's Avatar
I suffer arthritis in my hands. I have a pair of heated gloves and they are wonderful, unsightly, unwieldy and more like old fashioned gauntlets. But bloody toasty, so much so that I am considering other heated clothing. especially the socks
Not Grumpy, opinionated.
Old 09-11-17, 04:31 PM   #10
Chris_SVS
Chris_SVS's Avatar
I have the same grips, very much a generic fit and I had to cut down the throttle side grip a bit.
But very cosy in the mornings and with a bibio gizmo, they somehow remember the last heat setting so 1 press and they're on 60% with no faffing around
Chris_SVS is offline   Reply With Quote
Oxford heated grips vs. Keis Heated grips? MichaelM Bikes - Talk & Issues 41 21-11-13 12:40 PM
R&G heated grips dyzio For Sale - Other Bikes and General biking items 1 06-02-13 11:01 PM
Which heated grips? Springbokki Bikes - Talk & Issues 7 31-01-13 07:18 PM
Oxford heated grips and symtec heated grips Alpinestarhero Ancillaries 18 25-01-10 04:43 PM
Heated Grips NAPA121 Bikes - Talk & Issues 7 12-09-05 09:38 PM
