Old 27-01-18, 08:28 AM   #1
stinkerbill
Default SV Curvy retro racer project
Morning all!
So I've bought myself a curvy SV to do a sort of 'future-retro' cafe racer project on.
I'm not a mechanic and this bike will be mostly cosmetically changed, and simple-to-do mods at that, but thought I'd post about it here.
First off, here's a current photo of 'before' and a Photoshopped 'after'....
stinkerbill is offline   Reply With Quote
Old 27-01-18, 08:31 AM   #2
stinkerbill
Default Re: SV Curvy retro racer project
So, thus far I've done...
- Undertray and seat cowl
- Reverse cone silencer (gonna design and have fabricated a new hanger so I can remove the footpegs)
Coming in the next couple of weeks...
- Poly26 retro fairing
- Round headlight
- Brown seat and grips
Things to be painted
- Forks (will spray in situ)
- Frame (will spray in situ)
- Swingarm (will spray in situ)
MUCH further down the line, I might attempt to design and have built a new subframe/seat unit... but that's a long way off.
Quick question on spraying, anyone done their swingarm/frame/forks? What paint did you use?
(And yes,I know I can powder-coat, but I'm not mechanically skilled/experienced enough to strip my whole bike)
Old 27-01-18, 11:17 AM   #3
Had mine powder coated chrome silver, there's pictures of mine in my pictures.
It's not a bad idea to do strip the back end down and at least grease all the bearings and linkages.
Old 27-01-18, 01:14 PM   #4
As mavi says strip it to the frame and powder coat as the bearings probably need to be done
Sent from my PRA-LX1 using Tapatalk
Old 29-01-18, 04:45 PM   #5
stinkerbill
Yep, so I've decided to strip the swingarm and powder coat it
I've tripped at the first hurdle though! The front header stud nuts are buggered and they're not coming off without a fight. Gonna have a local pro get them off for me and basically remove/refit the exhaust, as having fought with (and eventually won) similar issues on past bikes I have neither the patience or the inclination to battle the headers off and end up drilling out the studs when they inevitably snap... my mech can have the pleasure
He'll also release any other horror bolts connected to the exhaust system for me so I have a clean slate... and clean bolts/nuts/studs.
I'll report on progress
Then I can strip the swingarm at my leisure and move forward.
Old 29-01-18, 04:50 PM   #6
stinkerbill
Swingarm/powder coating question, I assume to be powder-coated ALL bearings need stripping out, and attachments removed etc, they just have a 1-piece swingarm to work with?
Not sure what a powder-coat process involves
Old 29-01-18, 04:58 PM   #7
Yep, guaranteed to snap even if you wave a spanner at them
Yes, remove all bearings as powder coat will kill them, the linkage mount bearings will probably be difficult to remove without destroying them, but replacing them isn't a bad thing
Old 14-02-18, 03:01 PM   #8
stinkerbill
UPDATE....
So, the bolts did indeed turn to powder as soon as I waved a spanner at them. Quick trip to my local mech and they're sorted.
In the meantime, I've fit the new fairing and screen (yet to be painted) and fit a reverse cone silencer (sounds soooo good), bar-end mirrors, ditched the grab-handle, rear fender/indicator assembly, new under-tray and added some new bullet indicators.
Next step is having the fairing painted, fit (and then paint) the seat hump when it arrives and then start on the frame, wheels, swingarm and forks, paint the fairing bracket... lots to do!
Here's how she's looking currently...
Old 14-02-18, 04:21 PM   #9
Looking mighty fine
Old 15-02-18, 11:20 AM   #10
stinkerbill
After much deliberation, oggling of this Triumph cafe racer and realising that the imminent birth of my second child will likely mean no time to tinker for a good long while, I've decided to keep the wheels/frame/swing-arm silver and go for a grey metallic scheme.
So, here's how I'm hoping it will eventually look...
I can always add some pin-stripping tape and metallic vinyl graphics for details later
New member - Cafe Racer (ish) project. Tannoy964 Bikes - Talk & Issues 39 11-01-18 07:10 PM
Curvy Engine for Cafe Racer project. Bunkle Stuff Wanted 1 08-11-14 11:25 PM
Curvy cafe racer. monkimagic SV Talk, Tuning & Tweaking 38 13-10-14 08:04 PM
Retro fit, Curvy bodywork on Pointy? rictus01 SV Talk, Tuning & Tweaking 15 15-03-11 12:22 AM
Help me with Curvy scrambler-racer Project maxxdope SV Talk, Tuning & Tweaking 13 18-01-10 08:33 AM
