Old 18-03-18, 05:56 PM   #1
DomP
Default Clear eazi grips
Has anyone any experience of applying clear eazi-grips, I want them on my red daytona but I'm concerned as to whether I will be able to apply them without bubbles
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired
White 2011 YZF R125 sold
DomP is offline   Reply With Quote
Old 18-03-18, 08:52 PM   #2
LiamHarvison
LiamHarvison's Avatar
Default Re: Clear eazi grips
I used to have them on my SV - no problems with bubbles on application, but found that they weren't particularly grippy... Also, they discoloured after about a year (that was with everyday use though) and they started to peel around the edges.
Here's a picture of one after a year on:
https://photos.app.goo.gl/llXfS2iXEXGIH6zR2
Hope this helps!
LiamHarvison is offline   Reply With Quote
Old 18-03-18, 09:01 PM   #3
DomP
Hope this helps!
Are those the R&G eazi-grip as opposed to the brand Eazi-grip?
Old 18-03-18, 09:04 PM   #4
LiamHarvison
Ah, yep - apologies, didn't realise that they were different...
Old 18-03-18, 09:06 PM   #5
DomP
Yeah bit odd really, I think with my dry weather only usage they should last a bit longer
Old 18-03-18, 11:02 PM   #6
NTECUK
NTECUK's Avatar
I'd look at a few tutorial guides.
I have two air bubbles on my RS ..
Old 19-03-18, 12:08 PM   #7
johnnyrod
johnnyrod's Avatar
I've had Stomp grips on my curvy for a few years now, with a bit of care they go on fine, and they are grippy though you don't feel them through your leathers
Old 19-03-18, 02:03 PM   #8
SV650rules
I put clear eazi-grips on my AL7 tank and a few bubbles, really wish I had gone with a solid colour as there are a couple of air bubbles, which presumably will get bigger if the heat of sun gets on tank, also a couple of what looks like 'stress marks' that you get when you bend plastic. I also wanted to get them as near to lower edge of petrol tank as well because my legs are not the longest in the world, there is a little bit at the bottom that would not wrap around the radius and stick properly, and I am not about to try and trim it off now.
I went for clear because the only coloured bit on the bike (except black) is the tank and did not want to add more black - will post a piccy later.
2016 SV650 AL7
Old 19-03-18, 10:59 PM   #9
DomP
That's exactly what I thought clear could look like if they don't quite go on right first time and like you I don't want to cover up the colour of my tank
Oxford heated grips vs. Keis Heated grips? MichaelM Bikes - Talk & Issues 41 21-11-13 12:40 PM
Brand New & Unused - Stomp Grips (clear) magical_mover For Sale - SV's and SV related items 6 05-07-10 05:58 PM
Oxford heated grips and symtec heated grips Alpinestarhero Ancillaries 18 25-01-10 04:43 PM
HELP!!!! - Clear alternatives taillight - Clear or smoked!!!!!! insideyou SV Talk, Tuning & Tweaking 16 28-12-07 05:14 PM
Clear indicator lenses, fairing fitting kit, renthal grips BLK SV For Sale - SV's and SV related items 1 23-03-07 07:37 PM
